Question about Gateway Computers & Internet
I HAVE A GATEWAY M6866 I BELIEVE THE SCREEN WAS STEPPED ON & DOES NOT DISPLAY A GOOD IMAGE. THEIR IS NO VISUAL DAMAGE. THE COMP. WORKS OK WHEN PLUGED INTO ANOTHER MONITOR. IS TREIR ANY RESET FOR THE SCREEN,IF NOT HOW DO I GET ANOTHER SCREEN.
  • 55 Answers
Garmin 551s sonar stopped working, no bottom definition or ability to see fish GPS charts and speed all work It shows 3 step image repeats top of the screen / water surface has the transducer packed
Check you transducer cable route and connections. Look for kinks, punctures, & tears in cable. Visually check the transducer for damage. #2 check the units operation on a friends boat with the same set or research a local marine repair shop to check ops. Best of luck on the problem.
Jan 11, 2016 | Garmin Boating
Help. I want to disable the touch pad on my Gateway M6866 laptop. Whenever I am typing and get near the pad, the typing goes all over the screen. Any help will be appreciated.
Follow these steps to turn on or turn off the touchpad and optional pointing device.
  1. From the Start menu, click Control Panel.Note: If your Control Panel is in Category View, click Printers and Other Hardware.
  2. In Control Panel, click or double-click the Mouse icon.
  3. In the Mouse Properties dialog box, click the Device Settings tab.
  4. Click to select the device you want to turn on or turn off, and then click Enable or Disable.
Mar 13, 2011 | Gateway M-6866 Notebook
I have an LT Series Gateway Netbook. I am trying to connect to a Sony VPL-AW15. I am using a Sony STR-K7000 A/V receiver. The projector is giving the error message "Frequency out of range". I have...
HEy try changing the refresh rate
1. Right click on a empty space on the desktop and click on Screen Resolution. (See screenshot below)
2. Select the monitor Display you want to change the screen refresh rate for. (See screenshot below step 3)
NOTE: You will only be able to select a different display if you have more than one monitor connected.
3. Click on the Advanced settings link. (See screenshot below)
4. To Change Only the Screen Refresh Rate -
A) Click on the Monitor tab. (See screenshot below step 4C)
B) Select an available Screen refesh rate from the drop down menu.
WARNING: It is recommended to leave the Hide modes that this monitor cannot display box checked to prevent possible damage to your monitor.
C) Click on OK. 143d1229784117t-screen-refresh-rate-display-settings-monitor_settings.jpg
D) Go to step 6.
5. To Select from a List of All Display Modes -
A) Click on the Adapter tab, and on the List All Modes button. (See screenshot below) 7331d1238960189t-screen-refresh-rate-display-settings-adapter1.jpg
B) Select the display mode with the screen resolution, color depth, and screen refresh rate that you want to use, and click on OK. (See screenshot below)
NOTE: It is recommended to use a native screen resolution with a True Color (32-bit) color depth. 7332d1238960189t-screen-refresh-rate-display-settings-adapter2.jpg
C) Click on OK. (See screenshot below step 5A)
6. Click on Yes to confirm the screen refresh rate change. (See screenshot below)
7. Click on OK. (See screenshot below step 3)
Apr 28, 2010 | Lenovo IdeaPad S10e Netbook
An 'etch-a-sketch' - type image that at quick glance, looks like an elephant, appears in the upper right section of the screen. It isn't captured with print screen. Swapped out monitors to different CPUs....
I did see a similar issue with a Gateway display, the source of the image was the screen is damaged by the cover inside the screen. Basically, the inside frame was scratching the back of the screen making the image to appear until it damages the screen enough to turn off pixels.
Another possible cause are: "burned pixels", some kind of damage (liquids inside the display), the display was hit, or something like that.
The only solution is to replace the display or use it until is breaks (but it will be quite annoying).
Mar 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
The letter & noumber a90 is on the screen & wount move i can not get the camera to work i can not get the menu or display on screen
Hi there display LCD is damaged Or its disconnect from curcit board . Replace that LCD if damaged.example curcit board image in below.
Common problem.
Mar 23, 2010 | Pentax *ist DL Digital Camera
My Gateway MT6707's screen makes everything negative.
It sounds like the 'High Contrast' Accesabiliy option in windows has been truned on. This is a setting that a person who has visual imparement might use to be able to see the screen and text better.
To turn this off :
  • Click Start->Control Panel
  • Double Click the 'Accessibility Options 'icon
  • Click on the 'display' tab
  • Remove the check mark from 'Use High Contrast'
  • Click OK
Your screen will return to it's not color/size settings.
Nov 18, 2009 | Gateway MT6707 Notebook PC
Laptop screen purple psychedelic visual and then screen blank
Sorry to hear that you are having problems with the computer display.
Per your description, I believe the display controller was damaged by the power surge. The laptop may need replacement of the display OR use it with an external display.
Nov 06, 2009 | Computers & Internet
No signal on monitor
Do you have another monitor to test your computer? Looks like a surge went into the computer display and damaged the video card.
Sep 07, 2009 | XFX GeForce FX 5500 Graphic Card
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
Screen problem
Go step by step: 1. maybe you are trying to set a higher resolution then the screen can be 2. its possible that your comp don?t recognize the screen right, check the "display properties" make sure it?s the right model 3. reinstall the drivers. Restart. 4. if its not the software it?s the hardware, try connecting the screen to another computer if it works fine the problem is in the display board . Good luck
Feb 23, 2006 | LG Flatron 995FT 19" CRT Monitor
Computers & Internet Logo
291 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
