Question about OKI B6200 Laser Printer
IM GETTING LINES ON THE BOTTOM 0F MY PAGES LIKE LITTLE LINES THAT GO ACROSS THE PAGE ALMOST SMUGGES. WHAT CAN I DO TO CORRECT THIS?
  • 21 Answers
Remove cartiz.clean machine & cartiz.otherwise change cartiz.
Posted on Oct 08, 2009
Canon i3235
Are the lines across the page, in the direction of text, or from top to bottom. If from top to bottom, watch the scanner bar with the cover up, see if anything looks odd. If the paper moves in this machine, like from an auto feeder, it could pick up a streak from something in the path.
Checking, this unit is a laser printer. When replacing toner, there usually is a little tab thingy that is supposed to be moved back and forth over a little wire. The wire must be kept clean, too. Also, there may be a white bar with a glass cover that is to be cleaned very carefully every time toner is changed. Find this piece of glass, a speck of dust is probably your culprit.
Nov 26, 2013 | Office Equipment & Supplies
When I use the automatic document feeder on my xerox copycentre C20 I get a black line running the length of the page. If I make a copy from the glass, one sheet at a time, it is fine. Is there a way to...
You have something on your "**** glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
(Please rate this response as I'm trying to obtain the next level.)
Aug 04, 2009 | Xerox CopyCentre C20 Black and White...
My r285 priter is not printing ok it as lines across the page and also missingsome ink although all inks are full
lines across page caused by waste ink at bottom plate of head. Ink are full not guarantee good output. Check nozzle and some head cleaning.
Jun 09, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printing with a black horizontal line across bottom of the page
Wipe the cartridge.Use cotton but dont put water on it only cotton.if you have deiones water its good to use.
May 20, 2009 | HP LaserJet 5550DN Printer
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
White lines across the printed page - C1100 laser colour printer
Can you just reinstall your driver again,just to confirm that there is no driver problem.
Jan 02, 2009 | Epson Aculaser C1100 Printer
AL-1631 Copier puts a black line on each page
does the line go across the page & move ? then your drum needs to be replaced.
Dec 01, 2008 | Sharp AL 1631 Copier
Poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Nov 30, 2006 | Epson Aculaser C1100 Printer
OKI B6200 Laser Printer Logo
90 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
