Question about InFocus LP 540 Multimedia Projector
Infocus 540 has a blue tint to it. - InFocus LP 540 Multimedia Projector
  • 2,237 Answers
If it only has a blue tint when the computer or video is hooked up, reset the settings to factory default and replace the cables. if the splash screen (when it says "infocus") has the blue tint, one of the light filters are fried due to excessive heat and dust. unfortunately, you'll have to replace the entire optical engine.
Posted on Oct 15, 2009
Tip
I HAVE A INFOCUS LP650 PICTURE HAS A BLUE TINT CAN THAT BE FIXED
to replace the colorwheel:
remove the 4 brass and 4 silver screws from the bottom and the 2 silver screws from the back. through the top vent on the back panel and using a flat head screwdriver, unclip the 3 clips holding the back panel on. once removed, unplug the 2 wire harnesses. remove the top and front panel. now unplug the large wire harness and remove all the brass screws on the 2 power supply boards (also the screw for the ground wire). there is a black clip in the middle of the larger power board. remove the boards. now remove the brass screws holding the metal plate on. once removed, unplug the flat ribbon cable (for the colorwheel). now facing the front end, remove the lamp and the 4 screws holding the lamp housing (with fans) on to the bottom case. remove the tiny black screw on the small circuit board and remove the board. now you can get to the colorwheel. there are 2 small black screws holding the bracket. pull the ribbon cable through from under the fan. replace with new colorwheel and reverse the instructions. the only difference, remove the front panel from the top by undoing the clips. good luck!
on Nov 17, 2010 | InFocus LP220 Projector
Lamp for LP640 in focus projector gives off yellow color tint on screen
the blue polarizer is most likely damaged due to overheating and old age.
Jul 28, 2011 | InFocus LP640 Multimedia Projector
InFocus LP 540 is extremely dim
Dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspect its condition. You'll notice a black corrosion build up around the filament of the bulb.
May 02, 2011 | InFocus LP540 LCD Projector
I have two InFocus LP 540 projectors that simply do not indicate power when they are plugged in. Has anyone else experienced problems with the power supply? Is there a fuse somewhere that might need...
you can check the fuses (located on the power supply board where the cord plugs in), but it's more likely that the caps are dried out and need replacing, or the whole board itself. if that's the case, try av solutions in ny. they're an infocus service center and they're really good. www.avsolutionsny.com
Jan 22, 2010 | InFocus LP 540 Multimedia Projector
InFocus LP540 Red Tint
first swap out the source cable. if the problem persists, reset the settings to factory default. if the problem still persists, your colorwheel may be bad.
Oct 29, 2009 | InFocus LP 540 Multimedia Projector
The tint changes colors, green to red to blue, etc. while it is on. What's wrong?
you have a problem with the main controller board. unfortunately, there are no replacements from infocus. sorry.
but try to clean and resolder the edge connector (looks like silver fingers) contacts on the power supply where it plugs into the green plug on the main board. the main board may be getting fluctuations in voltage due to poor contacts.
Oct 14, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
I Followed the directions and changed the bulb. When
there is a burn spot on one of the light filters located next to the blue lcd panel. it is caused from excessive heat and dust. unfortunately, you'd need to replace the entire optical engine because infocus does not sell individual optical engine parts.
Oct 06, 2009 | InFocus Proxima UltraLight S520 Multimedia...
Projector gives off pink tint
when you have a tint on the projector its not a lamp issue, it is a connectivity issue you have to check the cables if they are connected firmly, or swap the cables with good known cables , if this doesn't help you have to send the projector to infocus repair center, since it is a DLP projector this may require engine /major repair
Aug 13, 2008 | InFocus LP70+ Multimedia Projector
Infocus lp 540
Also having this problem."Warming up" then "lamp didn't strike" then "retrying" stuck in a loop. It's at a school where I work and nobody has reported any messages regarding the lamp hours.
Jul 20, 2008 | InFocus LP 600 Multimedia Projector
InFocus LP 540 Multimedia Projector Logo
1,123 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
