Question about GE Advantium 120 Convection/Microwave Oven
How do I replace the fuse in a GE Advantium SCA1001KSS?
The dedicated curcuit breaker did not trip, and I have power at the recepticle where the unit plugs in. I lost power about 2 seconds after pressing the 30 second feature button.
    President:
  • GE Master
  • 1,922 Answers
Under the outer cover on a fuse clip its a special fuse avail at hardware stores
Posted on Oct 11, 2009
  • 3 Answers
GE Advantium 120 Ovens are easy to fix whenever they have or seem to not have any electrical power. Ship me your oven and I'll fix it for less then half the cost of a new one. Email: mckentucky@yahoo.com and write GE Advantium 120 on your Email subject line. You pay for back and forth shipping. I perform the repair for a very affordable cost.
Posted on Oct 31, 2009
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
Advantium 120 interior light won't go out
door switch is bad or out of adjustment I have a dometic that does this sometimes I just slam it a little harder
Jan 29, 2014 | GE Advantium 120 Convection/Microwave Oven
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    G.E. ADVANTIUM 120 JUST WENT DEAD NO POWER AT ALL.
    Bill,
    I have the same unit. It just happened to me. DId you find a resolution?
    I was using it on the oven mode and it just stopped working. It's completely dead.
    Thanks
    Bob
    Apr 11, 2010 | GE Advantium 120 Convection/Microwave Oven
    Advantium 120 blew breaker when door was closed. I reset breaker and it worked for three weeks. Breaker is blown again...when i open the door and reset breaker it works, but as soon as you close the door...
    I'd suspect the interlock monitor switch is stuck, or its mounting bracket is out of adjustment. This is designed to blow the fuse if you try to run the oven while the door is open. The switch is supposed to open when you close the door. This switch is replaceable, but you should have this oven repaired by a professional. There are lethal voltages present with the cover off, and the possibility of microwave leakage is the repairs aren't done correctly.
    Mar 20, 2010 | GE Advantium SCA1001SS Convection /...
    GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It...
    You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
    Feb 05, 2010 | GE Advantium 120 Convection/Microwave Oven
    I have a GE Advantium SCA 200 oven that stopped working as we were cooking. the Breaker is OK and there is power to the receptacle. Is there a fuse in the unit that can be replaced without a technician?
    Yes, it is a ceramic fuse inside the unit that can be easily purchased at your local Radio Shack. Take the original there and they will find the replacement fuse. Just unplug the unit before working on the electrical parts...
    Dec 19, 2009 | GE Advantium SCA2000B Microwave Oven
    GE Advantium mircrowave oven
    The problem with my Advantium was the fuse inside the microwave.Thanks to all of your fixya emailers ,I was able to change the fuse myself.I would recommend your site to all as you were a great help to me. Thank you, wlpasko.
    Apr 09, 2009 | GE Advantium SCA2000B Microwave Oven
    GE Advantium - No power at all - PSB2201NSS01
    Does the unit have power?If not check the back and see if ou can take off. Most unit have fuse back there.
    Mar 13, 2009 | GE Advantium 120 Convection/Microwave Oven
    GE Advantium 120 Convection/Microwave Oven Logo
    1,126 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    D. E. Hev
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
