Question about HP w1907 LCD Monitor
Monitor will not switch on
The hp w1907 computer monitor won't switch on but the computer turns on with the blue light showing it's on.
    Problem Solver:
  • 5 Answers
Your monitor could possibly have a backlight problem.. the wires to the lights are known to come off the lights in the screen.. if you try to check it your self be careful the lcd screen and lights are very frigile, nad can brake easly..
Posted on Jan 13, 2010
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: hp w1907 monitor stays on for a second when turn c...
It acts like it is not getting signal from the video card or it goes into shutdown mode to protect itself.
Try it on another PC first, if it still does not work then you will need to open iy up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 22, 2010
I recently bought a Hp Lcd w1907 Monitor off craigslist, the screen worked fine for about an hour then went black, button stays blue. Now every time I power on the monitor it stays lit for 3 seconds...
hi the cause is screen back light not working properly. you need to remove the back cover of the monitor to access the internal part of the monitor. then look for the connector of the cold cathode fluorescent tube back light going to the power inverter board of the back light you will noticed a dry joints which cause a loose connection that is why you hear a sound that cause of spark. you need to re soldered the connector or replaced if totally burned.
Nov 08, 2012 | HP w1907 LCD Monitor
Hp w1907 monitor won`t turn on
first remove thecover and remove all the power connectors from the smps the hold the 24 pin poerconector and short the green and black wire and see wether the smps fan is working if working remove the memory from the memory slot and clean the surface and insert it into socket and see wether the couputer boots
Oct 02, 2011 | HP w1907 LCD Monitor
Hello, I m working on hp w1907 when press the power button the led stay blue it does not change color but the screen light for a few sec. than shut down.
A component inside the monitor has failed - hardware failure, the monitor will have to be opened and tested to identify it.
The fact that the light appears on the screen shows the fact that the power source and the inverter are functioning - the failure is located in the mainboard. Because the status light doesn't changes color it means that the processor of the monitor is no longer loading the firmware - the damage is too great to be repaired. The board will have to be replaced and that will be expensive: $110 for a new board + the shipping to your location. If you don't have at least a basic experience in repairing electronics a visit to repair shop will cost you another $100.
In my opinion this monitor is not worth this much money: for $200 you can buy a bigger and better new one.
Aug 26, 2011 | HP w1907 LCD Monitor
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
HP monitor w1907 lcd switches off to standby.
your hp monitor has an electronic component problem inside, probably some busted capacitors or ccfl lamps that failed to light...best is to bring the unit to a qualified LCD repair center near you..
May 09, 2010 | HP w1907 LCD Monitor
HP w1907 LCD Monitor blacks out after 1 minute
Check your monitor cable, try to reseat it (VGA / DVi port) at the back of the computer. If it still does turn off try to reseat the graphics card (if you have an expansion card) If reseating wont fix it, try this monitor to another computer and see if it still turns off. if not, then it is a problem on the video card of your computer, if yes it means your monitor is faulty.
Hope this helps.
Apr 30, 2010 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Monitor goes black
I also have a hp w1907 monitor which also powered on for a second and then go blank with the power light still on.. it was out of warranty so I had no loss so I took it apart..I found one of the wires broken at one of the backlight bulbs { becarefull they are fragile and there is four of them, two on the top and two on the bottom... and the lcd screen is very fragile } I soldered the wire back on and it all work fine... just remember where all the screen parts go.
Oct 24, 2009 | HP w1907 LCD Monitor
My hp w1907 monitor turns on for about a min. then back off. What is the problem
Sounds like a bad inverter. Does the screen still show that the power is on? If so, then shine a bright light at it. If you can still see the image, then you have your answer. -=/ Daft Tech /=-
Oct 23, 2009 | HP w1907 LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
366 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
