Question about Canon imageCLASS D880 All-In-One Laser Printer
New cartridge installed a week ago. very dark imaging. tried adjusting exposure, cleaning rollers: no luck.
  • 56 Answers
Take out your cartrage again, if you look at each side of inside the machine there are silver contacts on either side. make sure that they are not dirty or bent and they make proper contact with the cartridge when inserted, if they dont the voltage will be missing that goes through the drum to limit the toner transfer, if there in no connection all the toner will appear on the drum and on the paper.
Posted on Oct 09, 2009
When I print the page is very black and hard to read...It has progressively gotten worse. Also, many times there is a duplicate image in a different place on the page. Something going on with the toner? ...
The first thing to do with double image is to replace the cartridge!
If you want to make sure that it is the cartridge, you can print a page, stop the printer in the middle of the run, open the printer, take out the cartridge, look inside the printer at the page, do not remove the paper yet, if the double image and dark page is there, your problem is from the cartridge, if the page is clean and nice as it should be your problem with the fuser unit and it needs replacment. Good luck.
Nov 23, 2010 | Office Equipment & Supplies
We are getting black faxes and dark grey copies
I recommend to clean out an optics. Take apart a cartridge and well blow through, clean the rollers and contacts.
Jan 14, 2010 | Brother IntelliFAX 4100 Laser Fax
Cannon 6 RE PC gives black copies
does the lamp under the platen glass turns on when copying? if not you might need a new exposure lamp...but if you get an image but its very dark, if you are mechanically inclined you can clean the mirrors and lens and the bottom of the platen glass because after many years of use dust will make the optics dirty and cause the copies to be very dark. hope this helps.
Dec 31, 2009 | Canon Office Equipment & Supplies
Make image darker
I found a link to the service manual kindly submitted by another poster here, there is some potentially helpful ideas there to fix problems like these: http://www.feedroller.com/Store/Service%20Manual/HL-1230,%20HL-1440,%20HL-1450,%20HL-1470N%20Parts%20and%20Service%20Manual.pdf
Check out p.165 and onwards. If you are like me, the easy service points like cleaning the corona wire and wiping the scanner window that you are supposed to do between toner changes never gets done as long as things work ok. Maybe you already checked that but if not, this could help.
May 15, 2009 | Brother HL 1440 Laser Printer
Dark blotches or patches in the printouts. Dirty roller?
hi
use a high pressure air compressor to blow the  printer clean then clean all the rollers with benzene and be sure to replace the toner tranfer roller if it is white, its situated under the cartridge . its a foam roller
Dec 11, 2008 | HP LaserJet 4200n Printer
Cannon PC1061 making dark copies
OR you can do it yourself.
your problems seems to be Dirty Mirrors.
Your copiear has 6 mirrors that need to be clean up. 5 of them are kinda easy access. the other needs to be clean thru something thiner than your fingers. (you can see the mirror but no way you can reach it).
Now dont worry (not yet) about that 6th mirror since THEORICALLY it doesnt get dirty.
So try first to clean up the other mirrors. and see what happens.
They are located below the platen glass (remove it) and be careful with the lenses (do not touch them). clean everything that seems to reflect light Or images.
If nothing changes you may want to try out with a new cartdrige. Your drum may be done.
Oct 19, 2008 | Canon PC1061 Copier
MINOLTA COPIER EP 1083 IMAGES TO DARK, NEW TONER, CHANGE PAPER
what is your exposure lamp brigthness condition? checkyour upper high voltage adjustment , check your exposure lamp & bright it & clean your copier lens.thanks.
Oct 05, 2008 | Minolta Office Equipment & Supplies
Adjustment program
Try cleaning the Auto Exposure sensor, or disabling the AE feature in standard settings. Some copiers have exposure calibration in standard settings too. Increasing the lamp intensity may cause further premature wear down the process line. (What machine have you got?)
Aug 27, 2007 | Gestetner - DSm660 Digital Imaging System...
Dark Copies
Jim, A couple of things: 1. OEM (Canon original) toner cartridge or remanufactured/compatible? The first place to start is always with the toner cartridge when image problems occur. Pull the cartridge out and draw back the drum cover. Check to see if the drum is a nice "clean" blue color or if the lines and spots are on it like you described. (These two areas should be handled by someone with experience in copy service) 2. The next thing would involved cleaning under the copy glass. Build up from dust, etc causes a "fogginess" that makes the machine try to adjust the intensity of the exposure lamp to conpensate for this. 3. Also could be a bad upper fuser roller if you started having any paper jams when to paper exits.
Jul 18, 2007 | Canon imageCLASS D320 Digital Copier
Replaced toner cartridge now doesn't work
If you pull out the paper tray you will see a rubber pick up roller. Clean that roller with a rag and some rubbing alcohol. It sounds as if the roller is slipping and not bringing the paper in fully. Good luck John
Jul 09, 2007 | Brother HL-2040 Laser Printer
Canon imageCLASS D880 All-In-One Laser Printer Logo
41 people viewed this question
old marine
old marine
