Question about Vector 3 Million Candlepower Rechargeable Sport Spotlight
I need a 90 watt bulb for my 15 millon candle watt
I need a 90 watt bulb for my 15 million candle watt vector flash light
  • 60 Answers
Check Home Depot, they should have it, if not in the store then online
Posted on Oct 08, 2009
I need a replacement bulb assembly for a Vector Power on Board 3 million candlewatt spotlight. The small light works, but the big one doesn't and you can see where it is burnt where the wires come...
Hi snikmn...
Disassemble the flashlight.
Take the bulb out and take it to your local auto parts place and they will be able to give you the bulb that you need.
It will probably be a 55/60 or just a straight 55 or 60 watt.
The higher the wattage the brighter the light, but the less time it can burn at that setting.
Please take time to rate me
Sep 07, 2011 | Vector 3 Million Candlepower Rechargeable...
How do I change the light bulb in my Vector ACV 127Y?
Remove the black rubber ring from the face then unscrew the reflector. The replacement bulb is the same that goes in most common driving and fog light and may be purchased at most auto parts and Wal Mart stores.
Aug 03, 2010 | Vector Spotlight - 1 Million Candles...
How do i find charger for cyclops 15 million candle power
INPUT: 120VAC 60Hz 18W
OUTPUT 12VDC 1A.
This is the spec for the 18 million thor cyclops which i presume will be the same for the 15 million.
Red light on torch flashes while charging. As soon as full charge is done red light stays lit.
May 19, 2010 | Camping, Backpacking & Hiking
Replaced battery in vector 139bw 3 mil candle power. single and double beam not working. How long does it have to charge? Where do I get bulbs for this modle?
You can get the bulbs fron Black and Decker, they service and repair all Vector products.since they were bought out in 2006. www.dewaltservicenet.com You could also have a defective battery or charger, it should take about 10-12 hours to fully charge.
May 15, 2010 | Vector 3 Million Candlepower Rechargeable...
The small flashlight on the handle will not turn off. When I press the button it goes off and then when i release it comes back on- can you assist?
It sounds like your switch is defective, unfortunately Vector lights are Non-Servicable except for replacement bulbs, batteries and chargers, so I don't think it is worth fixing.
Mar 19, 2010 | Vector Spotlight - 1 Million Candles...
I need 3 light bulbs for a 3 million candle power spotlight from Gordon 12Volts
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
Mar 08, 2010 | Vector 3 Million Candlepower Rechargeable...
I have been charging my 2 million candle power spot light for last 2 days but full battery charge indicator (red light) does not flash yet. the led white light is working but the main lamp doesn't work....
It should take 10-12 hours, any longer the battery is no good, you can test the battery using a Volt Meter, the battery should be reading 12 volts, any less and the battery will need to be replaced. You can order a new one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Feb 13, 2010 | Vector 20 Million Power Series Spotlight
I have a Vector VEC 189 10 Million candle power spotlight. Could you tell me how to change the bulb? Thank you
I have this same light and have lost the charger. can anyone tell me where to get one. Thank you
Jul 12, 2009 | Vector Camping, Backpacking & Hiking
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Vector 3 Million Candlepower Rechargeable Sport Spotlight Logo
175 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Jim London
Jim London
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
