Question about Refrigerators
GE Frig GSL22JFTA BS
I have GE model # GSL22JFTS BS and the water will not out of the door. I have checked the line on the bottom of the door and it is not frozen there. Still makes ice but no water. Can anyone help with this problem?
  • 4,070 Answers
If you get water at the bottom of the door then something is blocking it between there and the dispenser. Usually ice. Leave the door open and cover the freezer opening with a blanket to keep freezer cold.It should thaw in 156 or 20 minutes.
Posted on Oct 08, 2009
GE GSL22JFTA BA Side by Side is not dispensing water.
Check that the solenoid valve is working. If not, check that it's getting voltage when activated. If no voltage, control or switch is bad. If voltage OK, valve is bad. If none of the above, the water line is frozen.
Mar 18, 2014 | GE Refrigerators
Problem with my GE refrigerator model # GSL25JFPA BS freezer nor frig gets cold but there is still electric to it
check the gaskets on the doors to see if they r sealin proplerly if they r than that means that it is low on freon and it is cheaper to buy another refridgerator.
Aug 23, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Back wall of frezzer covered with snow, removed cover, coils frozen over with ice. have to de-frost freezer every 3-4 wks. Model#: GSL22JFTA BS
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE GSS25JFM Side by Side Refrigerator
Water dispenser keeps freezing GE Refrigerator
If this is a newer model GE side by side refrigerator, this is not uncommon. what you can do to check to see what is going wrong, remove the toe plate at the bottom front of the unit. Under the freezer door, you will see a white plastic water line, with an inline connector about 4-5" from where the line comes out the bottom of the door. this is normally a blue push-in type connector. On this connector, you will see two white sleeves on either side, push in on this sleeve while pulling the corresponding water line section out of the connector, if you squeeze the sleeve enough, the water line will slip right out. Place a towel on the floor, make sure both ends are on top of towel. Now, breifly actuate your water dispenser trigger, see if water comes out the exposed water line. If water comes out, your entire water dispenser system is OK, but, the water line in the freezer door is frozen, in which case the only way to melt it, is to turn the unit off, open the freezer door, and blow a fan for a few hours, to melt the ice INSIDE the door. You could also buy a new door, but that is very costly.
If no water comes out the exposed water line, then either your water filter is clogged, or you have a bad water valve solenoid
Feb 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Frig has water at door but no ice is made
Pour about 1/2 cup of water into the icemaker . If it dumps , replace the water valve . If not , replace the icemaker . Make sure the coils are clean of dust , etc... at bottom of fridge .
Aug 09, 2009 | GE CleanSteel GSL25JFTBS
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water and ice will not dispense
I had the same problem. I followed stills' suggestion and used a weed **** wire to push through the water spout. The weed **** did not go past more than 2-3 inches. Then I emptied the ice bin, used the hair dryer right close to the spout both from the outside and from the inside of the freezer door. After about a couple of minutes it started working! Now, just to check if the weed **** wire will go in more than a few inches I pushed it through. Now I was able to go well past 6 inches. So, before even you start addressing this problem try pushing through a weed **** line and if it is blocked then your problem is in the door. If not, then the problem may be in the reservoir at the refrigerator side.
May 23, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
578 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
