Wont perform channel search for first time set up.
Cant get it to perform channel search to set it up for cable. Just keeps going back to same thimg.
  • 3,866 Answers
Seems to me you have it on antenna channel search and not cable make sure its on cable and run it again.. If that does not work and your still having difficulties you might want to look to have it repaired.
Posted on Oct 08, 2009
WHAT is this tv digital ?
Dear Friend,
First, search for available air channels by going to you menu and then search for channel setup.
Second: change the option from Cable to Air Channels.
Third: after performing the channels setup you should be able to see free channels trough the air.
Good Luck!
Aug 06, 2014 | Shopnbc Insignia 39", 46" or 55" Full HD...
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Reset All Settings *Back to factory*
Unplugs everythings like all those cables boxes and the tv also,replugs the tv and those cable boxes,like Time Warner,Telecoms companies Veizon,AT&T,Dish Network,Direct tv boxes about an hour later.Let those boxes updates it softwares.Go in ur tv menu.Go to the menu selection PICTURE,go down select reset.That should reset the incomming broast Tuner board in the tv.Go to tv menu AUDIO,go down to reset.That should reset the audio setting.Now all those boxes have it updates softwares,and the tv reset it back to the factory setting.Now go to tv menu,go to SETUP,go down to CH. setup pick CABLE not AIR.Now the tv will go into scan modes to pick all those cable channels incomming broscast that ur pay for.
Jun 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Auto Search Function won't work...."can't set auto search"
Make sure that you have the cable option set correctly before you do the auto search. If this is set to "AIR", you'll only be searching for an analog signal. Hope this helps.
May 24, 2009 | Insignia IS 20" TV040919 TV
I have a durabrand 1907a and cant' get digitalchannels, please advise how I can get all digital channels? thank you duraproblem
Go into the CH SET menu. Go to the TV CABLE line. Set it to TV for antenna reception or CABLE for cable without a cable box. Go to AUTO CH MEMORY. Press the VOL + button to start the channel search. WAIT until search screen goes away. Check ALL your channels. Hope this helps.
Feb 17, 2009 | Durabrand DU1901 TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
TV WONT GO PAST CHANNEL 13
Go into your channel setup menu and make sure you selected "cable" and not "air". After selecting "cable", autoprogram the tv
Dec 06, 2008 | Televison & Video
Cant use all cable channels
Go to SET UP TV, press yes for the following question. SET UP GUIDE PLUS. This will take you to another GUIDE PLUS SET UP SCREEN. Answer the questions as they appear. The important question is going to be. DO YOU HAVE CABLE? Answer yes to this questions. Answer the rest of the questions as they appear. Then go back to MAIN MENU, select channel, then select auto channel search. This will find all channels that are offered by your cable package.
Jun 08, 2008 | Proscan PS32500 32" TV
Concierge series 25" wont stay on channel 3
You have to have the original remote. Then go into the menu under channel set-up. punch in channel 3 press add. The punch in channl 52. then press delete. Or turn on the cable box and go to auto tunnin g and let it do its thing. Im sorry , but if you dont have the original remote with a menu button your going to have to live with your problem. Good Luck
Jul 30, 2006 | Zenith C27A24T 27" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
