Question about Bamix De Luxe Hand Mixer
When I turn on my bamix it makes a high squealing noise
  • jnelsonbenne
    jnelsonbenne Jul 23, 2012
    Mine has also started to make the same squealing noise and has lost power. Any suggestions as to where to get it repaired in Ontario?
Shaft does not rotate motor workink
My Bamix stopped working--no shaft movement and loud motor noise (think disuse caused motor lubricant to thicken). Propped it upside down and put drops of quality machine oil at seam where narrow blade shaft enters larger shaft (in center of curved guard). Probably not necessary, but added a few drops where large shaft enters handle. Oil slowly seeps in. Attached a blade to manually turn for oil distribution. Did this periodically over several hrs. Turned on low speed and it gradually returned to full speed capacity.
Oct 25, 2013 | Bamix De Luxe Hand Mixer
My bamix attachments keep falling off, tried tightning them as per instruction book to no avail.
II had the same problem but I just kept adjusting it and make sure it fits into the notch, and it works. It a bit annoying, but persevere.
Best wishes
Jan 15, 2012 | Bamix De Luxe Hand Mixer
My Kitchen Aid Pro5 squeals when it's running. I may have overheated it when mixing bread dough. It seems to be running okay. It just makes a very high-pitched noise now. What can I do to fix this?
Get a Copy of the Repair Part List of your model from Kitchenaid.com.
Most likely it is the Worm Gear (17) grinding at low speed the Worm Gear Follower.(19)
You don't have to replace it now, but it is best to open the Transmission Housing and
inspect all the gears conditions. Clear all the grease to expose them. The Bevel
Gear (21) sits right on top of the Worm Gear Follower. (See Repair Part List)
If its teeth look sharp and all metal shiny, then that is the source of your noises.
Eventually, all the teeth will be chewed away and the planetary assembly will stop turning.
Jul 01, 2011 | KitchenAid 450 Watts KM25G0XWH Stand Mixer
I can't remove the blade from my Bamix hand blender
Shaft should be free for rotation that is ok.
Blade will come off with determined force of pull make sure grasp blade with towel to prevent injury to the fingers.
Dec 13, 2008 | Bamix De Luxe Hand Mixer
Basic mayonnaise
I have had that problem more then once.
You have to make sure your egg, oil,lemon, vinegar
are at room temperature. You will be very happy when it works. It is fabulous!
Good Luck.
Oct 13, 2008 | Bamix De Luxe Hand Mixer
Bamix slowdown - repair service anywhere out there?
click on the "contact" link in this website http://www.bamix-usa.com/ there's places in Canada & the US to have them serviced. Through contacting them they'll give you the nearest service area.
Good luck, love my Bamix!
Aug 11, 2008 | Bamix De Luxe Hand Mixer
Attachments fall off
Excerpt from: http://www.bamix-usa.com/
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers
Feb 23, 2008 | Bamix De Luxe Hand Mixer
Bamix hand mixer seems to be stuck
It says in the manual to soak it in very hot water for 10-20 minutes, then try again. This should free trapped food from the shaft
Oct 31, 2007 | Bamix De Luxe Hand Mixer
Bamix De Luxe Hand Mixer Logo
129 people viewed this question
Top Bamix Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Bamix Food Mixer Expert? Answer questions, earn points and help others
