How to replace belt on washer
I found my broken belt laying on the bottom of the washing machine. How do I replace the belt on this washing machine?
From the bottom, it doesn't look like I can slip a new belt on without taking about the pump and pully. I don't even see a why to do that!
Thanks,
Gary
  • Gary3 Dec 28, 2007
    Thanks for the reply. This is the first time I've used this web site so I added the model number to the subject line which doesn't seem to show up. It's a Maytag SAV365AAWW top load.
    Last night I had a chance to take your advice. I picked up a belt from the hardware store that was within 1/4" of the original. Since I never saw how the original one tracked around the pump and pullys, it took a few trys to get it right.
    In the end, I couldn't get the belt on. Either the belt is too small, or the original part will stretch to get it on. Do you know the specs of that belt? Can I use a hardware store belt or do I have to order one from Maytag.
    Thanks again,
    Gary
  • Gary3 Jan 07, 2008
    I got the new belt and installed it over the weekend. It worked!
    Thank you for your help.
    Gary
  • 447 Answers
Haha Yes With the very limited info you have provided us I still think I can help You just in the future be more specific. This is a Amana or Speed Queen washer?? To replace the belt Remove hoses from pump, remove wiring connector from motor, dislodge 2 front tub springs from tub end. Remove 4 -- 1/2 head bolts holding motor/pump frame to washer frame. Remove motor/pump from washer turn upside down. 3 Torx bolts hold pump to motor. Belt must be routed through pump proper. REinstall pump.
Posted on Dec 25, 2007
  • 2 more comments
  • joey  shearer
    joey shearer Dec 28, 2007
    First Gary im glad you took the time to reply here. You have saved yourself much aggrevation. You cant use just any belt because the washer will eat it up and spit it out in a short time. This washer doesnt have any type of clutch and it slips the belt on the motor pulley. You will certainly witness this once you get it repaired during the start of a spin with a large load. The belt must be the OEM belt that can take this abuse. As far as getting the new one you can buy it from any appliance parts retailer, or from www3.sears.com its a Maytag part # 27001007
  • joey  shearer
    joey shearer Jan 08, 2008
    Glad you got it repaired , gary
  • Rich Watson May 20, 2014
    yo, joey,,,how do i feed belt thru proper??
    you didnt explain how to get pump off motor,,,rich
What makes the drum spin?
There is a motor on the bottom. You can see it if you lay the machine down. The motor has a belt that attaches to a transmission. The belt could be loose or off. The transmission could be bad, or the spindle into the drum is stripped.
Jun 12, 2014 | Kenmore 22422 Top Load Washer
Why does my kenmore washer 110 fill with water but won't wash or spin?
Do you happen to hear a humming noise coming from the machine after the tub fills? This might indicate that the motor is spinning, but the belt that connects the motor to the rest of the machine works is broken. It is located underneath the washer. Tip the washer a bit and have a look. If it's broken, you'll probably find the belt laying on the floor. Take that to an appliance parts store where they can match it up with a new one. Installation is not too difficult. The belt will go around the motor pulley, the transmission pulley, the water pump, and in some cases, a spring-loaded tensioner. I hope this helps! :) -Jason
May 06, 2014 | Kenmore 22422 Top Load Washer
Switch not broken
Lay the machine on its side carefully you will b able 2 see from there
Oct 02, 2012 | Roper RAS6233KQ Top Load Washer
My washer tub nor the agitator spin or rotate you can hear a whining n grinding noise
whining and grinding most likely mean belt or coupler is binding or broken away unplug unit and open access panel or [remove water first]lay on side and access motor from bottom if belt driven check belt if frayed or broken replace-if has coupler [looks like a star shaped hard rubber /plastic piece between motor and trans] if broken pieces on floor or shredded replace- part's can be bought online-appliance stores coupler not expensive and both parts easy replacement good luck
Nov 08, 2010 | Washing Machines
Washer does not spin and I think the belt is broken, How do I open it to find out. It is a Maytag Ensignia washer.
If the back doesn't come off the you will have to lay it dowm on the front to get to the belt throught the bottom.
Mar 07, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
My kenmore 800 top loading washing machine just quit it wouldn't drain the water out and it wasn't spinning? It does make the sound of working when I pull the start dial but nothing happens
check the belt motor if loose or lost or it came out or broken. the belt is at the bottom of the washer. Remove the water using a cup and slowly and be carefull laying sideways the washer, then you will see the belt there, if you can not see the belt, that washing machine is a tranmission type machine, need to call Sears apliance service. ok
Nov 22, 2009 | Pool & Spa
Front Loader will not drain or start...
HI, check the following to address this issue.(nd=no drain)
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 25, 2009 | Maytag MAH2400A Front Load Washer
Kenmore 70 series washer does not agitate or spin and has loud clicking noise coming from area of either motor or transmission also found what looks like a belt broken laying on top of transmission but...
The problem you have sounds like a broken motor coupling. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The piece that you found could be part of the rubber bushing that sheared off. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupling can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
May 04, 2009 | Kenmore 15864/15862 Top Load Washer
Broken washer belt
This machine has no belt. It does have a motor coupling. Easiest way to replace it is to lay the machine on its back. Remove the pump cilps and slide the pump out of the way. Remove the motor clips (they may each have a 5/16 screw), and slidt the motor out. Replace the coupling and assemble in reverse order. Coupling # 285753 available at www.timerking.com for 9.99 or from sears. Hope this helps!
Feb 02, 2009 | Kenmore 24902 Top Load Washer
Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Aug 04, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
363 people viewed this question
Top Washing Machines Experts
