Question about Sport & Outdoor - Others
Sc552 aficio 2015 error code sc552 solution requre
Sc552-03 on my ricoh Aficio sp c830DN please what is the remedy
Jun 05, 2013 | Office Equipment & Supplies
I have a copier ricoh aficio 2550 and presents me code SC552. As the unlocking?
I have a copier ricoh aficio120 and presents me code SC552. As the unlocking?
Feb 13, 2013 | Office Equipment & Supplies
Sc552
SC-552 Fusing temperature warm-up error
The fusing temperature rises less than
7 degrees in 2 seconds, and this
continues 5 times consecutively.
The fusing temperature is not detected
in 25 or 35 seconds.
Possible Cause:
• Fusing thermistor defective or out of
position
• Fusing lamp open
• Power supply board defective
Aug 05, 2011 | Ricoh Aficio 2015 Copier
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Desperate!!! Ricoh AP3800C Error SC552 fixed last week now back
SC552 means that the pressure roller (Lower roller in the fusing unit located in the left hand door of the machine) is not warming up correctly. Is the copier installed somewhere cold? i.e. a garage? If conditions are ok and damp is not a problem, either the thermistor that controls the pressure temperature is defective, or the lamp that warms it up is defective. They are the two more common problems, might be worth looking for one on ebay. However they are approx 250 pounds so if you can find a second hand one thats cheap for spares I would recommend that. Email me if you have to do this and I will talk you through changing the parts.
Dec 23, 2008 | Ricoh Aficio AP3800C Laser Printer
Error code sc 500
Main motor lock error
Failed to detect main motor lock signal for 7 checks in succession (total of 700ms) after main motor started to rotate, or after last lock signal was detected.
Main motor defective
Too much load on the drive mechanism
Motor driver damaged
Oct 19, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Jul 15, 2008 | Ricoh Aficio 2015 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Sport & Outdoor - Others Logo
164 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
