Question about JVC HD-70FH96 70" Rear Projection HDTV
Its powering up then go,s off with flashing light
Its powering up then go,s off with flashing light on display and wont come back on
Change the bulb
Posted on Jan 08, 2010
All lights flashing, wont print
if you are experiencing quick flashing light on the display. then you will be needing to aquire a new power supply in particular 2xIRF450BPF components have failed on the power supply PWB located in the upper right quadrant. Belmonte Business Equipment have the Power supply in stock and can be sent or fitted.
Oct 11, 2013 | HP DesignJet 1050c InkJet Printer
I have a Sharp LC-22L 10M TV, it has gone off with the standby light flashing red and wont respond to any controls. If I power off at the mains supply and back on again it comes on for a second and then...
Flashing standby light indicates internal circuit problems. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there
Nov 26, 2012 | Televison & Video
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Have a canon mp 240 keeps flasing P and 3 and the alarm light and on button are also flashing......what the it wont scan it wont print does any one know what this means
When the Power and Alarm lamps flash alternately, and P and number (error code) are alternately displayed on the LED, an error requiring servicing might have occurred.
Turn off the machine, and unplug the power cord of the machine from the power supply. Plug the power cord of the machine back in, and then turn on the machine. If the problem is not resolved, contact your Canon service representative.
Nov 08, 2009 | Canon PIXMA MP240 All-In-One InkJet...
I have a phase linear uv7i and i cannot get it to power up. i have all wires hooked upand i get the power light to flash a couple of times and it beeps when i touch the power button but the display w
ok does power just flash or is it steady. flashing usually means your overloading it somehow and then it just wont play prob because circuitry protection. Ok and what do you mean anything else what else do you have and how do you have it hooked up and to what and what ohms at and what is your amp stable at. What type of subs.
May 12, 2009 | Car Audio & Video
Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
May 02, 2009 | Audio Players & Recorders
Mgr5875qdw
Hello sfgelectric,
Welcome,
You said, your broiler and oven won't work. That you set bake and it beeps and the bake light flashes but oven wont light.
Does the display flash any error codes, or just the bake light?
Fault codes
1. BAKE or LOCK may flash rapidly in the display to alert you if there is an error
or a problem. If BAKE or LOCK appear in the display, press the CANCEL pad.
2.If BAKE or LOCK continue to flash, disconnect power to the appliance.
3.Wait a few minutes, and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized servicer.
4.If the oven is heavily soiled, excessive flareups may result in a fault code during
cleaning. Press the CANCEL pad and allow the oven to cool completely, wipe out
excess soil, then reset
For most concerns, try these first.
Check if oven controls have been properly set.
Check to be sure plug is securely inserted into receptacle.
Check or re-set circuit breaker. Check or replace fuse.
Check power supply
I'll check the repair manual to see what I can find.
Let me know how it goes.
Perhaps this will fix a glitch.
Huuum
Remember to leave a rating.
Oct 16, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
JVC HD-70FH96 70" Rear Projection HDTV Logo
71 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
