Question about Sport & Outdoor - Others
Clear codes From the exchange of yesterday, I repeat. I reset the codes or cleared the codes with a Autoxray scanner, because I couldn't udo the battery cable bolts. Is this the same thing, please ???? Thank you; Paul L.
Error code H4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Toshiba studo120 H4 error code
May 06, 2015 | Toshiba e-Studio 161 Copier Copier
Throttle body code
try a hard reset by unplugging the the battery for a few hours...Also make sure your scanner has the capacity to clear the code ...not all scanner can clear certain codes...
Mar 21, 2014 | 2002 Jaguar S-Type
How do I reset the computer system on a 2006 Ford Explorer
Are you asking how to reset the computer or how to clear an error code/check engine light? Clearing a check engine light (which will also clear the error code) can be done with a code scanner. These are usually available for use at little or no cost at any larger auto parts store (they may even connect the scanner for you and record/clear the code). One word of caution, however: if you clear the code but don't repair the cause, the code and light will return after a brief amount of time. Now as for resetting the computer itself, not recommended that you try since error codes are stored in non-volatile memory. Disconnecting the battery's positive terminal for an hour or so may clear the check engine light, but, again, it will reappear and regenerate the error code unless the cause is fixed. Good luck.
Sep 29, 2013 | 1998 Ford Explorer
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
My pro 94 scanner shows the code luired when turned on. How do I fix this?
I'm guessing that the display shows "wired" and not "luired." This mode, along with the code, is supposed to clear when the computer programming cable is disconnected. If you don't have a cable connected, your only option is to RESET the scanner to its original factory settings. Just a caution: resetting the scanner will erase/delete all programmed information -- you will have to reprogram all of the data that you've previously entered. To RESET the PRO-94:
1. Turn the scanner OFF.
2. While holding down the 2 and 9 keys, power the scanner ON. The message "CLEAR" will flash for about 5 seconds while the scanner resets.
NOTE: Do not turn the scanner OFF until "CLEAR" stops flashing.
Bill B.
Listening in since the 60's
Oct 27, 2010 | Radio Shack Pro-94 Scanner
Hi, i want buy a ship (short money) code reader from ebay that reads Mitsubishi colt 1.6 glx 1997, and possivel more japonese cars, any idea? They all say that reads but i hve one (Vag405) and dont read...
Hi...
I'm a Mechanic.
And I Have Solus from Snapon. on My shop.
But I have Tried a lot Of OBDII code reader.
For me On my own OPINION. I say one of the better is AUTOXRAY.
With this Scanner you can Read Codes, Live Data. Freeze Frame, Pending codes,
And Clear the CODES.
This Kind of Scanners support, MB, BMW, AUDI VW, , All the Imports, from 1996 up to date.
Domestic From 1982 up to date. GM, FORD, Chrysler , Saturn.
Ok.. I hope this help on your question.
Thank you for use fixya.
Sep 18, 2008 | Mitsubishi Colt Cars & Trucks
I HAVE ERROR CODE H4
Give this a try, should resolve your code.
Aug 05, 2008 | Xerox WorkCentre XE80 Laser Printer
Sharp AR-5316
Never heard of an F2 on that machine. But give this a try.
Mar 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
If this does not clear the problem the fuser will need replaced.
Feb 20, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sport & Outdoor - Others Logo
19 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
