Almost all current Androids are the same for updates. From the main screen go into Settings > Software Update. You should see a screen that gives you the phone's current software version and a button for checking for updates. If you select About Phone from the Settings screen you should see options for the hardware itself including the kernal and hardware version.
Most manufacturer's have the phones by default periodically checking for and applying updates - including the phone's firmware, so you usually don't have to worry about it.
Hi, Try to rest it on factory settings and once it will complete then try to restart it and then update the firmware and check it. It may help you. www.ittechsupportonline.com
You need active internet connection for this: 1. press #0000#, then it will display you the current software version that your phone is using.2. press option, then select check for updates.3. it will then go to connecting to internet, select yes.4. if there is available update, you will be provided instructions that the phone is updating software.5. you will be ask to replace the old version with the new version, just select YES.6. your phone will restart, that's part of the software update.7. after restarting, your phone will now be using the latest version available for your phone.8. you can again check the current version of the phone's software by entering *#0000#, then you are good to go. You can also try to this:go to settings --> software update --> download available updates --> phone will restart --> you will be using the new version of the phone's software after this. Thank you for choosing www.fixya.com
You can un install old version of your Nokia PC Suite from your PC and install new from Nokia website for free. Nokia software updater will provide you to check any new software that is supports your phone.You can download and install in to your phone.
PC Suite will guide you to install application in your phone.
then enter the code which is located at the back of your phone. you can check the your current firmware by typing *#0000# from the standby screen
NOTE: PLEASE MAKE SURE TO BACK UP EVERYTHING BEFORE UPGRADING YOUR SOFTWARE/FIRMWARE
if it shows that theres a latest software version than the current version of your phone then upgrade your software using Nokia PC Suite. then it will reset your security code and settings.
to see what version u have take off the back cover and look under the battery. you can also call your service provider and read them your imei # they can tell u that way also. with this phone the software updates are auto, but go to "settings" then "software updates" from the menu. if this was helpful please mark it fixya
*#7370# should format and delete all data from your phone. But I do not understand the reason that Nokia Software updater does not update your software. Please give specific error it gives you.
Thank you
