Question about HP DesignJet 500ps (42 in.) InkJet Printer
Our Designjet 500 42 is not utilizing 42in
Our Designjet 500 42 is not utilizing the full length of paper. When I go into printer properties, it says Paper Avaliable: ANSI A. Do I need to remove the paper roll (full 42in) and reinsert it to get it to recognize the proper size? Is there anything I'm missing with regards to this?We can get up to about a ANSI B to print, but the printer properties won't let me select ISO sizes.
wayneard
  • 1901 Answers
SOURCE: Custom Paper Sizes for HP Photosmart C3180
I have a 3100 series HP. On it you select "Properties", then the "Features" tab. On that tab, there is a "Resizing Options" menu item. It has a drop down menu with "Letter", "More...", and "Custom" choices. There you can define the size.
Posted on Oct 15, 2008
  • 105 Answers
SOURCE: printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Posted on Nov 05, 2008
SOURCE: I have problem printing A3 size paper in HP DJ1280
dear use hp 1220c driver instead of 1280
the problem will be sorted-out
Posted on May 05, 2009
SOURCE: Paper mismatch error when trying to print a 5.5 x 8.5 document.
Changing the paper type to "plain paper" did the trick.
Posted on Jun 22, 2009
SOURCE: Paper Size Error: The specified custom paper size is not supporte
1. Press the OK button to bring you back.
2. Press the menu button repeatedly until paper size comes up
3. Use arrows to change paper size from automatic to whatever size you are looking for.
4. Start Copy
This worked for the HP Officejet 7210 All in one
Posted on Oct 20, 2009
SETTING DESIGNJET 5500 TO 42"
Setting your 5500 to 42" - this is done through the application ( eg PDF VIEWER) when selecting print choose print options or advanced in the next window that appeaers( driver panel) select the tab marked paper, in the next window you are able to set the size of the image and the size of the paper also whether youwould like the printer to transpose the print 90degrees to make more use of the media
alteratively you could open your printers folder select the DJ5500 and right click -select properties and as above choose the Paper tab to set as default the paper roll to the size required
hope this helps - if not please give more details that I might better understand your issue
Feb 13, 2014 | HP Designjet 5500 (42 in.) InkJet Printer
Designjet 750c mispositioned reload media, can you help me?
As these printers get some age on them I have seen them not load paper as they did when new. One thing you can check is to be shure the encoder stip is clean. It is the thin piece that streches the length of the machine and has very tiny lines that the carraige assembly reads to position itself as it moves back and forth. Be careful cleaning it so as not to damage it and don't cut yourself. Windex or alcohol will do fine.
Jul 14, 2011 | HP DesignJet 750c plus InkJet Printer
I have a z6100 designjet printer. I often print direct from Acrobat using the HPGL2 driver. The problem I have is: I rarely am given the option to delete the custom paper sizes that I have created. The...
just use your custom paper size and rewrite the settings.In some drivers U cannot delete the paper size from the driver properties.IF U still want to delete the custom paper size that you've created They are in the windows registry_but deleting keys from there is not recommended.
May 09, 2011 | HP Designjet Z6100 InkJet Printer
Yellow doesn't print
Confirm that you have yellow ink left in the cartridge.
Do a print head cleaning indicated in the printer utility program.
Also if you go to your printer in the start, settings, printer and faxes and right click on properties, you should find a head clean function.
May 06, 2010 | HP DesignJet 500 InkJet Printer
Hp Designjet 800 problem
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Aug 19, 2009 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
My HP 7280 printer has suddenly stoped printing on both sides
ONCE YOU HAVE THE DRIVERS INSTALLED DO THE FOLLOWING:
Go to START >> SETTINGS >> PRINTERS AND FAXES. Right click the printer in the PRINTERS AND FAXES window and go to PROPERTIES. Click the DEVICE SETTINGS tab Change the DUPLEX UNIT (FOR 2-SIDED PRINTING) to INSTALLED
Aug 06, 2009 | Office Equipment & Supplies
HP designjet 500 - system error 2110
Hi urlink:
This is your problem:
System Error: 21:10
Problem
Description:
Service Station failure. The possible cause could be:
1. The steps counted by the Service Station motor are not consistent
with the expected length of the current movement.
2. The Aerosol Fan has reached its maximum current limit.
3. The Service Station motor has shutdown because of blockage.
8-52 HP DesignJets 500 and 800 Series Printers Service Manual
Service Station and Aerosol Fan
Removal
NOTE Refer to the table on Page 8-4 for information on screw types.
1.
Perform the Service Utility "Unlock
Carriage" - Refer to Page 4-22.
NOTE Switch off the Printer after
performing this Utility.
2.
Remove the Right Hand Cover - Refer
to Page 8-7.
3. Manually move the Carriage out of
the Service Station.
4. Disconnect the Service Station and
Aerosol Fan Cables (connectors P5
and P9) from the Interconnect PCA.
You will need an HP certified technician to service this product.
Hope this helps
May 23, 2009 | HP PRINTER,DESIGNJET 500 42'' InkJet
Cant do EEROM setup coz severe error:0x4010008 occured
restart the plotter in service mode using following method
1 power off the plotter
2 press Up Arrow + Enter Button ( green buton) and while pressing both buttons switch on the plotter
3 when u see service test /Service utilities release keys & select service utilities & then perform eerom setup there , put the actual model number ( c7780b/c ) and it wil resole the issue
Mar 30, 2009 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Printer Properties not in English
Turn the designjet off at the back by the power plug.
Hold the "enter" button down and turn the designjet on at the back plug and the front plug switch, you should get a menu to choose a language
Feb 19, 2007 | HP DesignJet 5500PS InkJet Printer
HP DesignJet 500ps (42 in.) InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
