Question about Weber Grilling
The grill is not staying consistently lit, there are portions that get fire and some don't so it's uneven. I try to keep lighting those areas not staying on but they remain inconsistent. I believe it's got a clog in the pipe and wonder how to make it clear?
  • 464 Answers
You need to take out the burner(s) and clean the venturi tubes with a special long skinny venturi brush. the bugs are attracted to the smell of the gas and get in there and build nests or webs. it they are not kept clean you could even have a backflash because the gas can't get through the burners and comes back out the front around the valves and the knobs.
Posted on Oct 16, 2009
I'm having problems keeping the grill lit on my BEKO dvg593-mk2 gas cooker. This has been a problem almost since new, i have to depress the gas knob, and keep it pressed for about 5-8 min's after ingn
Here is the owner's manual or try calling customer service at 0870-241-1321 for help. http://www.manualslib.com/manual/15108/Beko-Dvg593.html?page=3#manual
Feb 12, 2015 | Grilling
Problem with fire staying lit. I start the fire in a chimney starter. after they are lit and i dump them into the smokey joe and put the lid on the fire slows or goes out. The vents are open. I have...
You may be emptying the chimney too soon. Give it time to ignite all the coals. If you spread out the coals too soon, they will not support each other to stay lit. You also need enough coals for them to ignite each other if one goes out. Every briquette should be touching at least one other unless you are doing a long, low-slow roast where you have a separate fire going to heat replacement coals.
Aug 05, 2017 | Weber Smokey Joe Silver Grill
Grill not lighting propery. It either does not light at all or it's a burst of flame. When its a burst of flame the burners stay lit and operate perfectly. Any ideas? I've tried adjusting the air...
Check for grease on the spark electrode-- does it showa large spark or not ----
try to light bbq with a match or bbq igniter ---- i would be shocked if it is a gas issue but if it lights it will be a bad igniter. ensure the sparking tips are clean and not broken
Dec 15, 2017 | Fire Magic 11-S1S1N-A Stainless Steel Gas...
Will not stay lit,I have a new gas tank and it light the first burner but will not light others and will not stay lit
Turn off the propane tank and disconnect the hose from the tank. Wait 5 minutes, reconnect the hose and turn the tank valve on very, very slowly, until it's completely open.
Now light each burner one a time and turn it to high. If the burners all light and the flames remain burning on high for more than a few minutes, you're back in business. Just remember to turn the tank valve on very, very slowly after turning it off each time.
If the above didn't solve the problem, are you sure you tank gas a significant amount of gas in it?
If that's the case (empty tank), when you replace it, do exactly what I said above when you connect a full tank to the grill hose.
Hope that solved your problem. Happy Grilling!
Feb 12, 2011 | Kenmore 882 sq. in. Cooking Area Gas Grill...
Burner will not stay lit
try to replace the regulator on the grill
Mar 20, 2010 | Ducane 30400042 (LP)
My kenmore elite grill has a ceramic cooking grid. it is 1 yr old.recently a problem developed. the ceramic grid lights as usual, but does not stay lit.once i let go of the knob the burner goes out. thanks...
check thermo coupling., its purpose is to keep heat at flame area-helps keep flame lit,like a pilot light... clean it with a finger nail file LIGHTLY- or use sand paper LIGHTLY, just to clean surface..
Nov 27, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Grill's fire won't stay lit
Try banging on the tubes feeding the burners with a heavy pair of vice grips or a hammer. It usually shakes the carbon loose to allow for free flow of gas.
Aug 09, 2009 | Grilling
Grill wont stay lit
These new tanks have a safety device installed in them . If you open the valve quickly or tip the jug the damn thang won't work. Take the tank loose, open all the grill valves and close all valves. Reconnect the tank and SLOWLY open the valve a hair. Light the burners. No need to open the valve all the way. if you do the dumb safety will plug the jug.
May 08, 2009 | Brinkmann Charmglow 810-7600-S Grill
Fire Magic won't lite
In order to not void your warranty you should not attempt to fix this yourself right now. Vendor has the legal obligation to be of service. You can even demand a full refund if they do not try to help. better business bureau could be of service in these cases too.
May 05, 2008 | Grilling
Grilling Logo
106 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
