Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
My dishwasher has a high-pitched whining noise shortly after I start it, and it continues throughout the cycle. My husband cleaned the water intake screen, thinking that was the problem, but it made no difference.
SolutionGuy
  • 331 Answers
SOURCE: Dishwasher Problem -REVISED
Debris in the pump. Professional service required.
Posted on Jul 29, 2007
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
reg501
  • 413 Answers
SOURCE: Loud whining noise while washing
It may be debris in the food chopper or the motor going bad.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Posted on Jun 10, 2008
Problem is with the main pump motor bearing. Water leaking from the face seal enters the front bearing. After some time, the bearing wears out bringing on the loud noise. The motor is easy to remove but the bearing requires some time to remove. I did not have access to a press so I ground off the bearing an replaced it with a shielded 8mmx22mm type. Grainger p/n 1L001. The part is only $9 compared to over $200 for a replacement motor. It takes some time and disassembly of the dishwasher can be difficult but take your time and be ginger with the parts. The root of the problem seems to be the impeller. It screws onto the motor shaft and seems to work loose after time. Since its tightness compresses the face seal, when it loosens water can seep. No way to lock it in place after tightening. Weak design point.
Posted on Sep 24, 2008
  • 11 Answers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Squealing noise
Here is Manual onlineManual online
Nov 04, 2013 | Baumatic Dishwashers
As soon as the motor starts up after the dishwasher fills, the motor makes a loud grinding noise that turns into high pitch whining. Water begins leaking from above the pump.
That shows a leaking water seal. Water would run into the motor bearings which then rust and make noise. You probably need the motor / pump kit.
May 20, 2011 | Dishwashers
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Mar 04, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Feb 23, 2008 | Dishwashers
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
High pitched whining noise from bottom of dishwasher
the arms are only turned by water coming out of them thro angled jets, they are not electrically driven. the noise will be coming from the circulating pump, probably one of the bearings. no cure except to replace
Mar 10, 2007 | Baumatic 18 in. BDW45.1 Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
1,626 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
