Question about Adtran Total Access 600R Router
Need to factory reset Adtran 600R
Is there a way to completely factory default an adtran 600r modem
5 Suggested Answers
  • 83 Answers
SOURCE: Adtran Telnet
Are you getting any failure msgs? Where are you telnetting from? Has your router been restarted? If you have web access turned on the router, you might be able to login via your browser, or you could directly connect to your router via a console cable to check your configuration.
Posted on Jun 23, 2009
JaxPlanet
  • 922 Answers
SOURCE: Can't connect Dell TrueMobile 1184 with Adtran NetVanta 3200
It sounds like you need to "crossover" the connection.
Using a crossover patch cable to connect the two devices is the first thing that comes to mind. (http://en.wikipedia.org/wiki/Ethernet_crossover_cable)
However, some routers/switches have physical buttons on ports to cross them over or you can use their web-based management to change port settings.
I hope this helps.
Posted on Jan 27, 2010
  • 223 Answers
SOURCE: I do not know the
Thank you for using FixYa
The default password is 'password' and then 'admin'
uaafqqavnaaaaaelftksuqmcc
http://docs.google.com/viewer?a=v&q=cache:2jM0LFDsYpEJ:www.andovercg.com/datasheets/adtran-netvanta-3430.pdf+Adtran+Netvanta+3430+Router&hl=en&gl=us&pid=bl&srcid=ADGEESj5spjwkyVJC6UyQDNwkyvakTTZSbWo4enx_ZgRd2xVMlQV1Xb-vUjtRni1jRfONgwG5SfKaIvKtgH0FFtuKhbjlU2nDcw8m1JheO2ZyLt3Vtv0hizo49rXEr_Ck7dj-wibAQ6B&sig=AHIEtbRallEW86bs2qN3VdcAR2SK5Nno6w
I hope this was useful and please comment if this was helpful to you.
Posted on Apr 29, 2011
rajendrasngh
  • 393 Answers
SOURCE: How do I factory default
Every router has a reset button on it.
Try to find that button and press it for 30 Second.
It will reset your router to factory setting.
I hope it will help you.
Thanks for using FixYa.
Posted on May 19, 2011
How does and Atlas 550 split to analog
The Atlas 550 is modular, and can break out the 23 channels as BRI or FXS. Since you want 23 analog lines, I presume you want regular 2-wire phone lines (aka, FXS lines). The you that by using 3 "Octal FXS" modules (8 port modules) in addition to the T1 module.
Read more here: http://www.adtran.com/web/appmanager/portal/Adtran?_nfpb=true&partNumber=1200305E2
Nov 21, 2011 | Adtran Atlas 550 (4200305L3) Multiplexer
I can not log into my adtran 624 router. How do I reset password?
There should be a reset button on the back of the router take a small pin and push and hold for 30 sec that will set the router to factory defaults you will loose any settings you have on it and will have to reconfigure it I have included the manual
http://www.adtran.com/pub/Library/Manuals/Default/Total_Access_600_Series_System_Manual.pdf
Aug 23, 2011 | Adtran Total Access 624 Router
How do I factory default adtran netvanta 1224st?
May 19, 2011 | Adtran NetVanta 1224ST PoE w/ UK power...
I do not know the password to acccess adtran 3430 router. how can I reset the router to reconfigure
Apr 29, 2011 | Adtran Netvanta 3430 Router
How do I reset an adtran 908 to factory defaults
Not every router has the button. For Adtran you would need to reload the box and as soon as you see the first prompt wait for "You have 5 seconds to press escape to enter bootstrap mode." In bootstrap you can type "erase startup-config" and hit enter and then answer "y" to "Erase startup-configuration? " and reload.
You also have an option to run "bootstrap#erase file-system" but that will erase all files in the file-system which I don't recommend you do that. Erase startup-config is better.
?I hope that was helpful :)
Sep 24, 2010 | Adtran Total Access 908 Router (4210908L1)
I hope this helps.
Jan 27, 2010 | Adtran NetVanta 3305 Router
Netvanta reset password
Enter admin as the username, enter your admin password, and click the OK button. (The default password is
password.) Here is a link to your manual:
http://www.wedophones.com/Manuals/Adtran/NetVanta%202000%20Series%20Quick%20Start%20Guide%20(Rev%20B)%202nd%20gen.pdf
May 25, 2009 | Adtran NetVanta 3200 Router
Adtran problem
try repalcing ethenet cable if that does not reslove issue either there is an accumulation of dust in the port or the port has gone bad.
Oct 11, 2007 | Adtran ESU LT Modem
Adtran Total Access 600R Router Logo
713 people viewed this question
Top Adtran Computers & Internet Experts
Gareth Tomlinson
Gareth Tomlinson
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
