Washer fills but won't continue washing
Washer fills and drains but only clicks when it comes to start the washing cycle
  • Anonymous Jul 13, 2008
  • 1,294 Answers
Did you check the hose behind the machine, the one that goes into the standpipe. This pipe should be about 3 feet above the ground before it bends into the standpipe; there is a water level mark behind the machine. And the pipe should not go too deep into the standpipe.
Posted on Dec 25, 2007
Water continuously drains and fills, and never gets particularly high
You will need to check you washer drain hose and make sure it is only inserted into your house drain pipe in the wall no deeper than 4-6 inches, alternately your house drain needs to be as high as the top of the washer lid. Be sure to secure your drain line from the washer to one of the water shut off fittings with a zip tie. You are most likely experiencing a siphon action because the washer hose is inserted too deep in the house drain. Pleazer Appliance...
Apr 17, 2014 | GE GTUP270EMWW Washer
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
Click if helped.
Feb 25, 2013 | Washing Machines
Drain pump won 't stop running
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
Nov 26, 2012 | LG WM-2277HW Front Load Washer
No water during any cycle.
if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
