Question about ASUS A9550GE/TD Radeon 9550 Graphic Card
Tv out hello, I cannot seem to get the tv out set up properly, can you help?
  • 27 Answers
Ya you may uninstall the previous version of it and install a fresh copy i think it will help
Posted on Dec 30, 2007
Scart signal
check the tv mode av1 av2 and pal settings
Sep 05, 2008 | Televison & Video
LG 42PX4MVH remote control does not operate the TV, it seems that it needs to be re-synchronised, how do I do it? The batteries was replaced yesterday and the lights on the remote control flashes and...
Hello
If you are using its original remote control handset with this set, replacing batteries will poise no problem at all. If remote control does not works properly check the following.
Check to see if there is any object between the TV and the remote control
causing obstruction.
Are batteries installed with correct polarity (+ to +, - to -)?
Correct remote operating mode set: TV, VCR etc.?
The light at its side
Illuminates the remote control
buttons of selected mode.
OK.
Apr 26, 2011 | LG 42PX5D 42 in. Plasma HDTV
My Onkyo TX-SR505 is not set up properly. (and i have no idea where the maual is) I cant seem to get any sound to work for the tv OR my Wii. Help? i can get video on the Vcr/dvd slot, but no audio.It use...
Hello
Send your email address to me by Fixya. I've the user manual of your Onkyo model. I'll send a copy or it to you by return mail. I can't send it to you by this site as it exceeds the upload capacity of this site. OK.
Apr 23, 2011 | Audio Players & Recorders
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions:
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
No picture on my tv
Details of your TV and whether you are trying to use component or not would help, however if you are on a new TV, you may have to connect the console to an older TV and change your Console Settings. It may be on a 480p setting. Do you hear audio? Need more details, please email me
xxsodasipperxx@yahoo.com
Dec 19, 2009 | Microsoft Xbox 360 Console
EVERYTHING IN WRITING IS DOUBLE AND THE PICTURE IS DISTORTED
Hello Tim this is a very common problem with the projection tv set, the problem is coming from the convergence board with faulty ICs that have to replaced in order for your tv set picture to work properly,they do sell convergence repair kits for your tv set but i would not recommend this the reason being is that if you make a mistake while changing out a component your whole tv set is gone not going to work anymore so for this i would recommend for you to call a near by tv repair shop and have a tech come out and change this ICs for you, after you change this ICs from the convergence board your tv set should go back to working normal on the link below you can check out how a convergence board looks like thank you hope this helps.
http://bestbuy.partsearch.com/content/pages/tv-convergence-boards.html
Aug 29, 2009 | Sony KP-46WT500 46" Rear Projection...
Channels won't come in
Hello divalisaf,
These are a few things I want you to check first.
1) Make sure the cable set top box is on and the cable is connected to the TV properly (This may seem simple but I have had to charge many people a $60.00 service fee plus a $70.00 travel fee just to turn on a cable set top box)
2) Make sure the TV is set to the proper input you are using (RF( F connector) , HDMI, Component video, and or Composite Video)
3) Make sure the TV is set to the proper channel (either channel 3 or channel 4 depending on your area) The cable set top box should be action as your tuner.
If all of these conditions are met, then we can begin troubleshooting.
First determine if the other inputs work (HDMI, Component video (RGB), Composite video (yellow), s-Video (6 pronged black cable).
If the inputs work then you possibly have a tuner problem
If the inputs don't work then then problem is likely in the video microprocessor.
If the problem is in the tuner or the connective circuitry then we will have to determine where to get a replacement tuner (or you can just use one of your other video inputs)
If the problem is in the video section (which includes the microprocessor) we are going to have to troubleshoot the video section which will involve you having a background in electronics, if not I would suggest having a qualified TV technician perform service on this TV.
I hope this helps,
Thank you,
Shuttle83
Nov 25, 2008 | RCA HD56W66 56" HDTV
My mitsibishi tv says its not getting enough ventelation and it shuts down. what can i do
Hello bobtail0915,
This means that your set is not getting the proper amount of air flow in order to remove dissipated heat from the set. I would suggest moving the TV to an area with better air flow. Make sure that nothing obstructs the ventelation slots on the back of the TV set. This should help.
Thank you,
Shuttle83
Jul 13, 2008 | Televison & Video
Help
few tv sets have extra head phone volume option but many has either way, I mean if you put head phone, speakers will be off.
I dont know the model n make of your tv set.
May 27, 2008 | Sony MDR-RF970RK Headphones
ASUS A9550GE/TD Radeon 9550 Graphic Card Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
