Question about Endurance TF6iHRC Treadmill
The treadmill will stop and brings up error 1. Can't find anything in the book. Please let me know what this error means.
Hi, E1 is speed sensor or motor related, you could try changing the speed sensor, you should check wires from speed sensor to board and check wires from motor to board, yoou can check you motor by plugging the live and earth onto a 9volt or 12volt battery to see if it turns. i suggest you check and clean the brushes in the motor, hope this helps.
Posted on Oct 08, 2009
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
Treadmill keeps stoping
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Jan 27, 2014 | Life Fitness Treadmill Precor C954 (Used)
My treadmill stops wen runing on it and brings up er 27 on screen
Corrective Action
My treadmill stops wen runing and brings up er 27 on screen
Corrective Action
How to reset treadmill T630
Dear Sir:
I will try to help you.
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
    • 5
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted
If you need further assistance, please reach me, sincerely.
God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 24, 2011 | Exercise & Fitness
Unlock the code on Precor treadmill?
Dear Sir:
Please try with this Reset system for Code:
    • 1
    • 2
    • 3
    • 4
    • 5
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
If you need further assistance, please reach me. sincerely. God bless you.
E.CUADRA
Oct 23, 2011 | Exercise & Fitness
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
Endurance TF6iHRC Treadmill Logo
679 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Tom Chichester
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
