Broken RCA D52W20 & Best Buy
I have been going back and forth with BB for almost 3 weeks now. The tech came out a week after I called and said our power board was fried. They could not locate another one but somehow BB has found one. I have a feeling this is a refurbished product, can we refuse it? Our extended warranty is up April 1st, Our luck it would probably die again soon after that.....Any advice?
  • 556 Answers
Any board you get for this set will be refurbished if you want your tv fixed then let them put the part in, if you refuse the service then I expect your contract will be no good anyway.
Posted on Oct 08, 2009
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52inch d52w20 not powering on, green light comes on then goes
If you have to ask, its best that you let a trained tech do it. The horz. transistor controls the H/V -flyback basically a switch for high voltages. when it fails you get no power up. Julio milleniumtvsvc@gmail.com It can be very dangerous to work with.
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 inch D52W20 hdtv ready television
Replace 3 capacitors cp150- 2200uf 16v ////cp114 and cp120---- 220uf 35v. buy caps at Radio Shack.
Dec 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can anyone tell me why my screen is red when I turn it on then it shuts of power. it's a RCA D52W20
You either have a shorted red crt or the video IC on the red crt board is shorted. The problem is that there is about 30,000 volts running around that crt. It is best to have an experienced tech determine the exact problem
Dec 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20 Power Problem
ore there ares some ribbon cables that need to be reseated going from the deflection board to the signal board
Nov 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
52 in RCA
The RCA needs a flyback if its an ITC222 chassis which is waht the D52W20 RCA is. You can get a replacement flyback at the following link with free tech support so you can do the repair yourself which is a very easy repair. You need flyback number 259296. As far as the XBOX you should never play any video games on a rear projection TV as it can cause burn in on the CRTs if it is paused. video games are best played on a direct view, plasma or LCD TV. Rear projections like the RCa is not a good idea because of the possible burn in. heres a link to your flyback 259296
http://servicemanuals.vstore.ca/
May 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken cable connection inside board
No need to buy a PC board. Have professional tech solder leads back and tighten connector
Apr 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
