Question about McCulloch Garden
I have Mcculloch Mac 10 10 chain saw year unknown
I have Mcculloch Mac 10 10 chain saw year unknown new spark plug gas mix replaced will not start
    President:
  • 2,220 Answers
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Posted on Oct 08, 2009
  • dontbother10
    dontbother10 Oct 09, 2009
    If no sputter check for spark at the plug.
    Problem Solver:
  • 14 Answers
Clean or replace carb.
I have a McCulloch 2618 cav chain saw and the chain adjusting screw has broken. How do i replace it.
[PDF]IPL, McCulloch, Mac 2618 CAV, 952802079, 2008-05, Chain Saw www.mcculloch.com/ddoc/MCCI/MCCI2008.../MCCI2008_AAaa__545014313.pdf
  1. Cached
  2. Similar
CHAIN SAW MODEL(s). 545014313. Mac2618CAV. DATE. 3/04/08. Replaces. PARTS LIST. 545014313 -- 5/31/07. Ref. Part No. Description. Ref. Part No.
McCulloch MAC2618CAV - Chainsaws
www.mcculloch.com > McCulloch International > X-ref > Chainsaws > McCulloch
  1. Cached
  2. Similar
Newsroom · Parts & Accessories · Chainsaw parts & ... MAC2618CAV. Select model, 006 · 050 · 10 ... McCulloch MAC2618CAV ' Bar Length - 18 inch/45cm ...
McCulloch MAC 2618 CAV (952802079) Chainsaw Spares & Parts ...
www.ransomspares.co.uk > Parts > Garden Spares > Chainsaws > McCulloch
  1. Cached
  2. Similar
Buy genuine replacement McCulloch Chainsaw MAC 2618 CAV (952802079) spares from an authorised supplier. Price match promise and next day delivery.
McCulloch Chainsaw Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/chainsawpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch chainsaw model below to find OEM part numbers. ... McCulloch MAC 2618CAV Chainsaw Type 1 and 2
McCulloch Trimmer Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/trimmerpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch trimmer model below to find OEM part numbers.
Mac 2618CAV - McCulloch Spares, Parts & Accessories
www.4mcculloch.co.uk > Chainsaws McCulloch Mac 2618CAV SGO002 Spark Plug. Genuine spare part. Suitable for: McCulloch Mac 2618CAV. Type: SGO002 Commonly used in small handheld ...
McCulloch Mac 2618CAV Chainsaws Chain ' BuySpares
https://www.buyspares.co.uk > Chainsaw > McCulloch > Mac 2618CAV
  1. Cached
Buy your McCulloch Mac 2618CAV chainsaw Chain at BuySpares - choose from an extensive range of McCulloch chainsaw parts and McCulloch accessories. McCulloch 2618 Google Search
Nov 29, 2016 | McCulloch Garden
Chain saw won't start
Things to check,drain and re fill with fresh fuel/oil mix, replace the fuel filter in the fuel tank, remove the spark plug, rest on top of the cylinder and check for a spark, if this is all ok remove the muffler and check the condition of the piston through the exhaust port, any signs of damage and the saw will have to come apart for further investigation.
May 30, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Hello,I have Mac 110 model#600016c It`s in need of a little TLC The saw is about 25yrs.old and has never hadany work done on it.I need to know what the spark plug gap should be and what the gas/oil mix...
Spark plug gap should be: 0.020" and the fuel to oil ratio is 40:1. Be sure to use fresh fuel and a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Mix well in it's own container and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 01, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
When trying to pull start my Mcculloch chainsaw 338, its all jerky. ok last season. Help please.
Take the spark plug out and pull the cord to see if it stuck.
Drain all gas and get a new mix.Put back the sp and start.
If thr cord was unable to pull,thr pisto and crankshaft must be service.
Oct 26, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
This saw looks new but it been in storage for years and the rope is realy tight it beraly turns once and its hard what can i do to get it to start its a mac 110 z62.1 class 1c
If your having problem turning the engine through ... remvoe the spark plug and use regular oil in the cylinder. Tilt it so that the plug hole is straight up and pour about 1 ounce of oil in the cylinder. Then pull it through with the starting rope. I would do this several times until the cylinder appear to free up. You have corrosion on the cylinder walls. The oil will help the piston and rings scrape off that corrosion. After the oil then use mixed gas in the spark plug hole and pull it through again. Make sure the gas is purged then attempt a regular start. If it has been is storage for a long time you may have to change the diaphram in the carb as they dry out and get holes in them / crack after being cycled with new fuel. Good Luck.
Kelly
Sep 07, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain saw won't start after not not being use for 10 years.
Chainsaws are a 2 stroke engine, when you use mixed fuel in a saw or any type of two stroke machine and let it sit, the oil in the fuel will varnish the inner workings of the engine.Sort of like eating lots of fat foods and getting clogged up aterys. Carburators are notorious for clogging up on 2 strokes. Most people mix there gas a little rich to be on the safe side so when you let this mixture sit without the engine running it through it will clog up everything. This is why when you are done for the season you should empty out the fuel tank and then start the engine , this will burn all the remaining fuel up and nothing will be there to clog it up over the winter. So with a saw thats sat for 10 years. Shes clogged! Get a carb rebuild kit, clean everything with raw fuel, no oil. All the smallest little holes will be plugged up"Jets"Use air to blow through everything.Then mix some new fuel up and it should work fine. Another thing to watch for with all of this is, inside the fuel tank, if fuel sits for too long it will harden up the fuel line. Sometimes it will actually break off inside the tank. Preventing the engine from getting fuel.If you use a little flash light you can usually see inside the tank and check this as well. Hope this helps. Have fun!
May 03, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel mixture for a Mac 2-10 Chainsaw
Recommended mix (Super 2-10A) on the attachment; Please do not start this saw if the wind is blowing west or your grandchild is down wind.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/1e87155fc8467cd988256b620016ca79?OpenDocument
Mar 16, 2010 | McCulloch Garden
How to check the spark plug is ok on a McCULLOCH PETROL CHAIN SAW MAC 436
Chain saws are still two-cycle engines (gas and oil mix) and they foul the spark plug pretty rapidly if not in perfect tune. Remove the spark plug and re-attach the wire and let the plug contact any metal part such as the cylinder head. Make sure the gas petcock is off and the start switch is on. Pull on the recoil starter and see if you have a spark jumping from the center electrode of the plug to the outer electrode of the plug. Clean and re-gap the plug and try it again. If no spark, the center electrode could be broken up inside the ceramic insulator and you can't see it. Try a new plug. If still no spark, another component of the simple electrical system could be bad. If your saw has a capacitor, change that out also. Sometimes the small coil that rides very close to the magnets on the flywheel comes out of adjustment. Proper gap for that is a small piece cut from a cereal box and placed between the coil and flywheel while re-tightening the coil bolts. Do not let the coil scrape on the flywheel. If any of this has helped, please rate accordingly. Good luck.
Jul 06, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
433 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
