Question about LG LMV1630ST Microwave Oven
The molding around the left hand side of the door has come up. It looks like it could be clipped back on but I need to take the door off. How do you do that?
  • LG Master
  • 9,047 Answers
Please post a new question, and please include your brand name and the full model number from the tag in or on the unit as well as detailed symptoms so we can help you.
Posted on Oct 10, 2009
Why will the door not lock and stay closed ?
Ithink the door clips spring is loose inside so openthedoor cover orjust move your door clips by hand it must not be too loose
Dec 08, 2014 | Amana Microwave Ovens
Bulb ZMD30STQX change
Some microwaves have a small square door on the left side, some clip shut, or screw removal. If not! you will need to remove the top "unplug first" bulb is located on the side or back.
Mar 15, 2012 | Zanussi ZMD30STQX 900 Watts Microwave Oven
WERE IS MODEL NUMBER ON KEMNORE RANGE?
The model numbers on most Kenmore ranges will be located on a nameplate along the oven door, or lower drawer opening. Some models may have this information on the back of the operator console.
If this question is in reference to a microwave oven, the model number will be located along the oven door opening, or inside the oven cavity along the upper portion on either the left or right hand side.
If you need further assistance, please let me know. I hope this helps you.
Oct 06, 2010 | Kenmore Microwave Ovens
How do I replace the door handle on a KHMS155LSS Kitchenaid microwave?
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This should be a very simple repair that you can easily perform yourself.
If you have any questions, please post back and let me know. You can refer to this illustration, if you like, to assist you as well:
http://pcappliancerepair.com/model-display.php
Mar 19, 2010 | Microwave Ovens
Replace handle on Ewave microwave
you'll have to remove the molding and the handle clips in to place and also has to screws that hold it in place, after that reassemble the door outside trim.
Jan 19, 2010 | Microwave Ovens
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Replace handle on adeantium sca1001fss01
you have to take the door off and pop out the plastic molding around interior of door. You can do this by sliding a screwdriver around the edge until you can get your fingers in. Be careful because there are some small plastic tabs that will break very easily. Next, remove screws on the backing of the door. There are similar tabs holding the backing on even after the screws are removed. I used a pair of insulated pliers and used the handle to pry the tabs back. Be careful because the tabs will break easily. Then the screw handle is exposed. Pretty easy huh?!!!! I just comleted this process and am looking for a handle. I am sure I will have to super glue some areas since I broke the tabs off.
Good luck
Jun 01, 2009 | GE Advantium 120 Convection/Microwave Oven
Light and door spring
I had a tension rod break in my door as well. There are two of them that cross forming an X and you can see them when you open the door and look in the crack. Fixing them is very easy once you get the outer panel w/ glass and the black molded plastic piece off. WARNING, when you open the door there are two screw on the inside top part of the door assembly. THEY ARE THE ONLY TWO SCREWS HOLDING THE ENTIRE FRONT PANEL/GLASS ASSEMBLY IN PLACE. I found this out the hard way. When the 2nd screw disengaged the whole assembly came crashing down shattering the glass and nearly cut off my toe. Be very careful when taking off the outside panel!!!
Next challenge...the black molded piece that also needs to come off. To remove this take off the piece that surrounds the exhaust tube to get at two screws that are directly underneath the molded plastic piece. After getting that off you have access to the two rod and can get them installed without to much trouble.
Again, be very careful when removing the front panel. My repair went from an 18 dollar tension rod to a $200 dollar front panel and nearly cost me a toe (yes, I was barefoot).
Aug 07, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Broken handle
1) Have to remove the door first; top of the oven there are two screws closest to the door, take those out. and the door should lift out
2) flip the door on the table with the handle side down. starting on the handle side there are three clips (top, middle, and bottom) between the outside casing and inside trim. Using a thin screwdriver gently twist starting at either the top or bottom to pod the two casings apart. work your way around the door.
3) You should see one of the screws that hold the handle on (top) but the bottom screw is under the metal casing so you need to remove the screws around this casing as well to get the other handle screw off.
Once you start you will see it isn't as bad as this sounds. I bought the handle for $40.
It is a shame that this is so cheap and breaks off this easily. Surprisingly we have had ours for at least 6 years before the handle broke and we have 3 girls opening and closing this all the time so I guess I was one of the lucky ones.
Hope this helps and good luck
Nov 20, 2007 | GE Advantium 120 Convection/Microwave Oven
GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Dec 05, 2006 | GE JVM1650 1000 Watts Microwave Oven
LG LMV1630ST Microwave Oven Logo
44 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
