Question about Alesis Monitor One Mk2 Speaker
One speaker fell ... no sounds ?? can it be
One speaker fell ...blue light is on but no sounds !!... can it be repaired ... any chance to do it in London ?? could i buy just one 2 replace it ?
    Sergeant:
  • 192 Answers
Most likely, if the LED is still functioning on the speaker, then an internal connection has simply come loose. If you use a screwdriver to remove the woofer (the large speaker) you will gain access to the inside. You should be able to both easily see the loose connection and reach it to plug it back in.
A little less likely, but also possible is that a part of the internal circuitry is broken. But, usually in those cases, the light stops working as well.
I hope this helps.
Posted on Oct 08, 2009
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
My X-mini speaker fell down and won't work anymore. How do I fix it? please help.
i have the same problem, it fell but now the blue light still work but no music is playing
Apr 13, 2011 | Audio Players & Recorders
Whole system is mute, power is on but theres no sound comming out even changing the audio input cable
Firstly make sure you are getting power to the speakers - there is usually a light to indicate that the speakers are turned on. If you DO get a light - then turn up the volume all the way and touch the green input jack with your fingers - that is the jack you would plug into the PC - when you touch the jack - you should hear a scratching sound come from the speakers - if u get NO sound - chances are that the speakers amplifier is blown (it is a small Integrated circuit that most electronic engineers would be able to repair)
Good luck
Feb 03, 2011 | Logitech Z-4 Computer Speakers
My pen drive fell into water...and it is not working and no light also glowing.....how to repair it
your pendrive circuit is damaged and you have to exchange it with the transcends service centre. if you didn't use it for 2 days when it was fell in water then it have a chance to work fine. Now no ways to repair it .
Oct 01, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Radio wiring diagram for a 96 thunderbird with premium sound
1996 Ford Thunderbird Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Black/Orange
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Illumination Dimmer Wire: Light Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: Dark Blue
Front Speakers Size: 5′ x 7′
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Jan 13, 2010 | Car Audio & Video
No sound
Restart your PC. Check all the connections in the back of the main base, and check that you have plugged the connector into the headphone jack and not a microphone or line in jack by accident
Apr 13, 2009 | Dell 5650 Computer Speakers
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Sep 29, 2008 | 1996 Ford Explorer
Fell and now cannot access the drive
there can be 2 problems:
1) VIRUS INFECTED
2) DLL file is infected
May 17, 2008 | Fantom Drives 120 GB Hard Drive
Harman Kardon Elegant 2.1 speakers problem
Chances are you have wrecked the cone and movement with the overly high input. Nor repairable if this is the case. Check out the makers website for more tech info
May 13, 2007 | Harman Kardon HK695 Computer Speakers
Alesis Monitor One Mk2 Speaker Logo
215 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
