Question about Car Audio & Video
The cd player on my renault scenic does not eject, it only beeps when I push the eject button. Please help! There is only so much of the Talking Heads I can listen to ... I don't know what the brand of the CD player is, just the one that comes standard.
KaeZoo
  • 156 Answers
SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Posted on Mar 15, 2007
chiquititas
  • 1010 Answers
SOURCE: cd player comes up with err message
Oh, i had this problem several times... look, the best answer that i can give you is to buy a new one, there's sony's cd-players that are great, me and my father have. now, if you want to stay with this cd player just insert the cd several times until it will play. but again, you better buy a different one.
Posted on Jun 18, 2008
  • 3 Answers
SOURCE: RENAULT SCENIC RADIO CD PLAYER
in most of the systems require cleaning and oiling why is that they fail.
should be greasing all the pieces where the mechanism is to move Apollo and pieces of plastic where the engine was working for Apollo
Posted on Sep 16, 2008
SOURCE: cd keeps ejecting
use a product called cd kleen it.you can find them on ebay.they take care of problems like this.
Posted on Nov 10, 2008
LVT7857
  • 116 Answers
SOURCE: Cd wont eject
You are absolutely right about bose! And GM Delco as well. Try this. I've had 50/50 results. Need 2 peole. One at the nattery, the other at the cd player. Turn the key on, radio will power up. with the radi powered up,disconnect the negative battery cable from veicle. Wait a few minutes. Now this step might be cumbersome. While holding stereo in your hand, push the eject button and HOLD while the other person re-connects the negative power cable back up. Ths will do a reset on the stereo and you may get lucky!
Don't put anymore cd' in it. Your only other option if you want that CD bad enough is to disassemble the case of the stereo and manually move the mechanism to eject it. Hope this helps
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
My cd won't work in my Renault scenic
try taking the cd out and putting it in upside down. the cd error should show on the screen. then eject and put in right side up
Jul 14, 2014 | 2003 Renault Megane
Removal of cd player from renault megane 55 plate
where is the cd player in a renault grand scenic 55 plate
May 07, 2012 | 2005 Renault Megane Scenic
Qx56 2004= trying to load a disc but when inserting about 1" of disc in, system said push eject. I pushed eject but then system switched to FM mode. Now I cant switch to CD mode when push CD button....
Sounds like that the cd is jammed inside the players so you could either take the player out the dash and open it up yourself or take it to a dealership/repair shop for them to fix it for you.
Also there might be a small holes located under the cd slot big enough for a pin to release the cd manually?
Jul 29, 2011 | 2004 Infiniti QX56
How do i enter the code into my mk1 renault scenic cd player.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Philips Renault Code Entry (For cars with a Steering Wheel Remote Control.)
Note: If your car does not have this remote control, then please reply )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
Mar 19, 2010 | Durabrand Car CD Player and AM/FM...
Fujitsu Seimens Scenic C600, how do you remove CD Rom
If you press the disk eject button on the front of the CD ROM drive and it doesn't eject the CD. Then try right click on the CD drive icon and then click eject.
If this doesn't work, then straighten a paper clip and insert it into a small hole on the front of the CD drive just below the CD tray and push the paper clip gently and the tray will pop out slightly, then you can grab it and pull the tray out to get access to the CD.
Sep 20, 2009 | Fujitsu Siemens SCENIC C600 PC Desktop
I have a renault scenic 2000, replaced battery need to input the radio code, noticed on this blog that you can push numbers 2, 5 and on button, I did this and my radio came on without me having to inp
Some radios hold the codes for a few Min's.However ,Disconnect the battery again and leave disconnected for an hour.Then reconnect and Enter codes and confirm.Should work ok.
May 29, 2009 | 2000 Renault 181
My renault scenic radio says code i am unable to enter the digits for the code
Hi - the way to enable code mode is to turn off the radio - then hold down 2&5 & press the on button - this will bring you into the 0000 code mode.
Regards Paul
Feb 22, 2009 | Renault SCENIC Cars & Trucks
Sep 12, 2008 | Car Audio & Video
Cd player comes up with err message
Jun 16, 2008 | 2000 Renault 181
Renault espace
The bumper is held on by just two 13mm bolts, the problem is getting to them. First remove the air filter and you will then see a black junction box on the right hand side, remove this and the bracket underneath to get to the bumper bolt. The driver side bolt is behind the small black junction box under a larger black junction box. Remove the small one 2/3 small bolts) to access the other bumper bolt. Its easy to do just takes a bit of time.
Mark
Jun 13, 2008 | 2000 Renault 181
Car Audio & Video Logo
381 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
