Question about Water Heaters
My temperture on my hydro bath seems to be faulty
My temp on my hydro bath seems to be faulty saying it is 40 with no water in it what could be the problem i think it could be the tem probe that is situated in the bath problem is once i put water in the tub the temp goes up and once it hits 49 it cuts the motor off so the jucuzzi will not work the water temp is no where near that temp so somthing not quite right..please help...
    Champion:
  • 248 Answers
TIME TO REPLACE SORRY TEMP GAUGE NOT BATH BEST OF LUCK
Posted on Oct 30, 2009
How do you adjust the temperture
turn the knob. really, the same knob that says pilot is also a temp gauge.
Mar 14, 2015 | Water Heaters
How do i know if the control unit is bad on an aquastar 1600H
That voltage does not seem high enough. Supposed to be 1.6 VAC and I got 2.5 VAC. Do you have the water flow turned to the maximum? Is there something blocking water flow? The hydro voltage should be checked separetly from everything else, so if you can't get the VAC higher, my guess would be that's the problem.
Nov 19, 2014 | Bosch 1600H-NG Natural Gas AquaStar...
How do I set water temp to 140 dgrees on a 7-50
turn hydro to it off first, open the two or one access doors not sure if it has two elements move insolation back and you will find thermostat use flat driver and turn to desired temp do same on both elements if it has two push back insolation screw covers back on turn on hydro
Oct 06, 2014 | Water Heaters
How to changed the temperature?
There should be a thermstat under the cover you can adjust.
Feb 01, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Seems that the bottom is leaking. Water is hot. Should I replace the thermostat?
Leaking is not repairable, replace the unit, UNLESS the water is coming from an overflow or overheat circuit, in which case, lower the temp and test again.
Jul 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Just purchaced a 99 jamboree with an atwood G6a-8e water heater. while on a trip I lit the water heater, and after 30 minutes someone told me water was leaking from the side. I noticed the pressure relief...
It's gas operation only, but has electronic ignition for propane. ( just to confirm, if you look at back of water heater, it would have a metal or black plastic cover and hydro cable going in side or top of it.)
There are usually 3 things that may cause pressure relief to leak. 1) Faulty,corroded pressure relief valve, which usually needs to be replaced if it goes faulty. 2) water temperature is getting too hot, which could indicate a faulty thermostat. 3) If your hooked up to city water, the pressure may be too high, causing excess pressure build up in hot water tank, thus pressure relief opens. If your running off your on board pump, this is probably not the cause, as they are usually set at 40 psi.
Ist, - try pulling lever on relief valve slightly open ( careful it's hot !!) to clean out any calcium that may be logged on seal thus causing leak. If that doesn't do it, and the hot water isn't running out steady and appear to be under extreme pressure while leaking, then I'd change the pressure relief valve. Remember when you do, shut off water to system, and relieve pressure by opening a tap, and pressure relief as well after that. New one shouldn't be too expensive, just make sure you get same thread, 1/2"NPT or 3/4"NPT. Use a little teflon tape, or pipe dope whatever you prefer when re-installing as well as clean threads a little before.
If it really starts gushing out pressure relief when heating or heated, and water seems hotter than normal, it's more than likely a faulty thermostat. I'll wait for your reply on what condition your experiencing before I go in to how to change the thermostat.
Nov 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
Heat is on water is going in cold but not coming out hot copper coming out of tank is room temp;
Your gas valve may be faulty and need replacing as it is not sensing the change in water temperature in your hot water tank,
Feb 14, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Hot water not very hot..also seems low in pressure
pressure temp valve leaking
tank leaking
hot water line leaking
shut off water to tank and leave sit for 4 hours turn on water tap and test temp if hot you have a leak
Oct 17, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water Heaters Logo
63 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
