Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
No ice instead water dripping down into freezer making icicles
    Scholar:
  • 103 Answers
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Posted on Oct 10, 2009
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
My GE Arcitia refrigerator ice maker makes ice but sometimes the ice in the bin starts to melt and drips down inside the freezer and makes big icicles.
You have a leaking valve allowing to much water into into the tray. Its fairly easy to change out. It could also be the defrost terminator is allowing it to stay in defrost too long. If it is only the water, yet ice cream stays hard, it is for sure the valve which is about $30.00. It is located in the back down at right corner. just pull off plugs and replace with new one.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi, My refrigerator has been working perfectly for ten years. A couple of nights ago I noticed that it had wasn't freezing the ice and water dripping down inside the freezer part at the internal of the...
peter if your unit doesent seem to be cooling and the commpressor sounds like its running sounds wierd but make sure the fan cooling the evaporator coils is running if there is a lot of dust also clean the coils just a thought
Apr 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Our refrigerator just suddenly started to make this loud grinding sound..it appears to be coming from the freezer side. I turned off the ice make and reduced the freezer temperature but it still keeps...
This could be a failure of the evaporator fan. Also maybe some ice has formed from water dripping from the ice maker and had now produced an icicle which could be hitting the fan blade of the evaporator motor. Remove back cover to the freezer/fan and check the fan operation while it is running.
Mar 29, 2010 | KitchenAid Refrigerators
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is dripping and forming an icicle at the front right of the ice maker
you need to defrost the drain hole and clean it out... sounds like it is frozen
May 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice build-up in back of freezer
you probly got a water inlet spout froze over.. take out ice maker and look where water inters icemaker and see i that is froze
Aug 23, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
228 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
