Question about Panasonic Lumix DMC-FS5 Digital Camera
When i turn on my camera the screen is blurry, and a box comes up that says "turn off camera and turn on again", but it just does this continuously.
  • msawat Oct 08, 2009
    The lens comes out all the way and the cover opens all the way. You can hear the servo run after the lens extends all the way, and then the message comes on to turn the power off and then on again. Doesn't help.
  • Terry Herrera May 11, 2010
    have you noticed if the lens comes out all the way, and the lens cover if it opens all the way
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
Sony DSC-S700 when turned on sometimes the screen is blurry and pink toned with blurry grey lines running accross the screen. Photos turn out the same. Happens intermittently. Have changed batteries,...
Hi there some how your camera LCD pressed by out side & the screen is damages. That's why you get the lines. Specially its come some particular area in the LCD screen. Just the way of resolve is resolve the LCD screen. Thanks & waiting for your feedback.
Apr 01, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 13, 2009 | Olympus FE-230 Digital Camera
My camera cant focus on anything
It seems as if the lens isn't installed properly, make sure it's screwed in right in its mount.
Tom
Jun 20, 2009 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Blurred images on the lcd screen and pics come out blurry
number 1,make sure you have lithium batteries,energizer prefered.2 put it on auto focus.3dont be too close on the object your trying to photograph,and 4 do not zoom in too close on object either.this should solve your problem,good luck,hope i helped
Apr 30, 2009 | Samsung S860 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Cannot Zoom in or out
I took the battery off and then put it back on and when I turned it on it worked fine! Thank you
Jul 03, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Is blurry
turn on the flash.
Apr 12, 2008 | Polaroid I533P Digital Camera
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Panasonic Lumix DMC-FS5 Digital Camera Logo
54 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
