Question about Canon Office Equipment & Supplies
Model # MF5530 Paper jamed when i switched from 20lb to 24 lb paper. Now it seems like every other copy james and looks like accoridan. I have cleared machine of any paper and reset the paper release levers on the back of the machine to origional position.
  • 2,984 Answers
On the roller that feeds the paper through, it seems to have become misaligned...can you look inside or at the back end of the feeder tray?
Posted on Oct 08, 2009
Gestetner 6123 paper jaming feeding section copy printer
nrg 6123 copy printer after make stencil line on copy soulition
Jun 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
After each copie the lights of jamed paper and the first bac of paper are display and i can'tcopie whithout clearing them
1-please check the paper path for any foreign objects droped inside(like pins)or any small pieces of torn paper.
2-check all paper detecting switches for free actuation and nothing prevent it from paper detection.
Nov 28, 2009 | Sharp AR-M205 Copier
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
Workcentre 24 wrinkled paper when copier used
Its a jaming and cutting shits leave some litle bit peace of them///finde of them and remoove
Mar 24, 2009 | Xerox WorkCentre M-24 Color Copier
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
A4 R shows in the window
A4 is referring to a europpen size paper. You may have some paper jamed behind the paper tray. You will have to take the paper trays out and look in side for some paper jamed in the rear part of the copier, remove and you should be set..
Sep 10, 2008 | Toshiba 2060 Copier
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
18 people viewed this question
old marine
old marine
