Question about Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW
Whirlpool ART 804/G/WP - freezer keeps completely
Whirlpool ART 804/G/WP - freezer keeps completely freezing up and fridge part also freezes. there is a thermostat in fridge goin 1, 1.5, 2 through to 5 and a switch that when flicked has an orange led light come on. but with no manual not sure what is what! id thermostat for fridge or freezer? what is the orange switch for? how can i get a manual?
  • 1462 Answers
SOURCE: Freezer not keeping items completly frozen
thius suggests the defrost system not working and the defrost drain blocked. take off the back panel inside the freezer, melt off excessive ice and free the drain at the bottom with hot water and patience
Posted on Apr 30, 2007
  • 236 Answers
SOURCE: What does the orange light stand for on a
fast freeze, switch the f/f button off and see if the light goes out!!!
Posted on Apr 19, 2009
  • 7 Answers
SOURCE: frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
Posted on Aug 24, 2009
Controlfrk
  • 304 Answers
SOURCE: 1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Posted on Sep 08, 2009
  • 47 Answers
SOURCE: Frigidaire FRE196A
you know where you adjust the temperature of your fridge. its a knob with a line that increase in thickness. or it may have numbers written on it. before you replace it. try adjusting that knob to set it to a higher temp. please if your taking the covers off the replace thermostat,, please turn the power off first.
Posted on Nov 11, 2009
Why is my whirlpool wrn28nwb6 not freezing?
Check your defrost timer also make sure its turning also there's a thermostat and heating element that defrost the ice at given cycles
May 16, 2014 | Freezers
Frigidaire LFFU14F5HWH Not Completely Freezing
Maybe It Needs Regasing Some Fridges Have a Swich Between The Fridge And Freezer If They Are Fan Forced That Gives Off The Same Symptom As Being Out Of Gas Or Low On Gas
Nov 06, 2013 | Frigidaire FFU14F5HW Upright Freezers
The edge of the wall between the freezer and fridge is very hot
This is normal. There is an electric, (mullion), heater behind that surface that keeps condensation from forming. It also keeps the freezer door gasket from freezing to the surface and ripping when the door is opened.
Jun 01, 2012 | Whirlpool Freezers
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
Freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
Jan 29, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool FRS Side by Side Fridge Freezer
Hi Simon I saw that problem because you have a hole in the bottom of the freezer connecting directly on the wall of the fridge you need to block it ... because the air flow directly from the freezer 2 the fridge . Hope it was helpful.
Francois
Aug 01, 2008 | Whirlpool Freezers
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW Logo
201 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
