Question about Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum
High pitch My Hoover fusion vacuum cleaner began making a high pitch sound that makes it very annoying to vacuum. I cleaned all the things I could clean. I even cut out all the hair that was entangled in the brushes. Any idea what is causing the sound. It sounds like an siren is going off.
  • Anonymous Oct 15, 2008
    high pitch problem it still picks up dirt but i don't want to blow the motor out
  • hulettk Mar 19, 2009
    I have the same problem. It's not a clog, at least not a clog in a place there should be one. I broke the entire vacuum down to the motor and even though they have filters between the motor and outside air, it still had small strings stuck inside the fans of the motor. Essentially, to fix this issue, you would have to take it in to a vacuum repairman, because Hoover designed the inflow air filtration poorly. There is no reason, with the filters in place, I should find strings caught inside the motor. They slapped this vacuum together and put it on the shelf. The Hoover name is a joke these days. I wouldn't even trust their new high end line of vacuums. Going to look into Dyson and Sebo vacuums. Unfortunately, they are expensive, though closer to the high-end Hoover line in termns of cost, just better overall design and value.
The Hoover Fusion has design flaws in the motor, including a metal plate that is too thin to contain the forces acting on the motor, particularly the constant strong tension from the drive belt, and a plastic plate that is attached to the metal plate by two screws that gradually loosen over time. Assuming the filters and canister are clean, a high-pitched noise coming from the motor indicates it is about to fail as a result of these problems. You can replace the motor after it fails, but the problem will eventually occur again. For those very mechanically inclined, when the motor first starts making the high-pitched noise, you can dismantle it and tighten all screws.
Posted on Jul 10, 2009
There are two filters, both are accessed after you remove the container. One is at the top, simply unlatch and clean or replace.And one at the bottom, which is supposed to filter the incoming air for the motor. If you remove those filters and turn on the power and the sound remains, it's not likely the filters however. Fine dirt and even large particles can get inside the fan motor and create a problem, causing greater vibration and a high pitch noise like it wants to explode. The motor needs to be opened and cleaned thoroughly or replaced by a repairman. The cost may not be worth it.
Posted on Mar 19, 2009
    President:
  • 1,673 Answers
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
Posted on Jan 22, 2008
High pitched sound when power on
I had a vacuum cleaner that did the same thing. My vacuum had three suction levels. The noise level would decrease as I lowered the level. I also noticed that when I turned the vacuum off the sound didn't stop instantly, it wound down/faded off as the motor slowed down. I found the problem to be the bearings in the main motor. I've been told that the motor that powers the carpet brushes can also make the sound if the motor bearing fails.
Dec 29, 2012 | Kenmore Progressive Bagless Upright with...
Last night vacuum started making high pitched sounds. Sounded like motor was running way to fast. The hepa filter on side of product was blown off. I checked the belt, and was in tact but has a few...
Hello, I don't belive it is the filters, the motor sounds like it is bad, whihc will be happen more offen on bagless vacuums, they need more reapir work. The best choice for a vacuum is a bagged machine, and Miele / Riccar and Oreck are the Best. If I can help feel free to call 1561-848-3387 Thank you, Teresa. Clean sweep Vacuums.
Aug 10, 2010 | Hoover U5296-900 Upright Vacuum
High pitched sound
make sure the filters are pushed it all the way and the pipe work is clear
Jul 26, 2010 | Dyson DC25 All Floors Bagless Upright...
I have two older Filter Queen (brown vacuum cleaners). Besides unclogging the hose area and making sure it is not filled with dirt, what else would cause the machine to run hot and have a high pitched...
High pitched sound is often caused by air leaks in air ducts. This will also cause hoover loosing sucking power and slightly overheating.
If the hoover is overheating a lot, then noise can also come from the motor. In that case the part must be rplaced.
Try replacing the cone filter, the secondary filter, and the insulation at the top of the machine.
If that does not fix the problem, then the hoover must be taken apart to clean or repair the air duct.
Nov 13, 2009 | Filter Queen Majestic Canister Vacuum
Loud rattling noise.
Hi there SmartAlec from NelsonVacuums.com.au here. Often when an upright is making a rattling noise it can be something caught in the roller and every time the brush turns it knocks against the body and since it turns really fast it can sound quite bad. Take the roller out and clean inside that area and see if that helps. Hope it does. Happy Vacuuming :)
Aug 03, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
High pitched noise
It sounds like you may have a bearing problem. The motor bearing eventually gets damaged by the water vapor that is drawn in by the fan. This will cause a high pitch squeel from the motor. It is possible to replace the bearing, but it should be addressed by a professional techician.
Jan 27, 2008 | Hoover F5886-900 Steam Vacuum
High pitch noise
Most likely it is coming from the motor bearings, you will have to replace the motor.
May 23, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum Logo
1,109 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
