Question about Canon PIXMA iP90 Mobile Printer
It seems to work, paper comes out, ink cartridge moves freely,it just wont print
  • 3 Answers
I have had this problem myself, the ink has dried inside the print head, I used isopropyl alchohol (IPA) after removing the head and carefully cleaned the head using a soft cloth, also I dripped a few small drops onto the mesh where the ink goes from the cartridges into the head itself, placed it back into the printer, popped in some brand new cartridges and printed a good few test pages to clear it all out, do this quite quickly so as not to degrade anything inside the head.
hope this helps you
Posted on Oct 11, 2009
Cartidges wont move
the cartridge as you call it is the carriage, which houses the inks and printheads, Its supposed to be 'Locked' at the service station until such time as the printer is ready to start printing,
what you should look for is a strip of what looks like clear plastic that runs the lengh of the print surface, give this a GENTLE clean with a cloth damped with WATER, ensure there is no paper blockage along the print path the cycle thhe power allowing the machine to come to ready or fault displayed
Mar 09, 2014 | HP OfficeJet Office Equipment & Supplies
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
recommendation:
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
Screen says cartridge cradle is stuck but it moves freely
Ok there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | HP PhotoSmart 7760 InkJet Printer
Empty incoming faxes
Check to make sure the ink is coming out of the cartridge as this often takes some coaxing with a new one. Take the cartridge out of the printer and dab the print head on a piece of paper and check to see if the print head leaves a mark on the paper. If you see 2 stripes on your paper it means the cartridge is okay. On the other hand, if there is no ink mark left on the paper it means that the ink is not flowing freely from the print head. In this case, fill a saucer or old coffee mug with hot water and place the cartridge in the water so that only the print head is submerged. Leave it for a few minutes and then dab it on the paper again to see if the ink is flowing.
Please let me know if this is not what's causing the problem.
Best wishes,
Graemevm
Apr 30, 2009 | HP Officejet 5510 All-In-One Thermal...
Heavier weight resume paper was apparently misaligned and started to jam printer. I pulled paper out and now carrier is stuck in middle, the power button and paper jam button both blinking. I tried...
Although you got the paper out of the printer, there may still be some small pieces jammed under the print head. You may have to manually move the print head to get at the small pieces. You need to make sure the printer is unplugged before you try this. Once the carriage seems to move freely plug the printer back in, it should move to the right where it will come to rest. You should go through the change ink process, but just take out the one that's already in there and then put it back in again. Also run the head cleaning, alignment, and print test utility before attempting to print. If you still are having problems there may still be pieces of paper stuck in the print head. In that case repeat the process again. I hope this helps you.
Have a great day!
Carol.
Apr 13, 2009 | HP DeskJet 5550 InkJet Printer
Not printing
Have you checked if your cartridge protective tape is removed. There is this transparent tape in your ink cartridge contact area especially for HP printers, you need to remove it so you can print.
It would be helpful if you put in the actual unit with your question...
Mar 10, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Both colored & black ink tanks are new but nothing comes out
I have had this problem before. Try removing print head and cartirdges. get warm water in bowl and swirl head in water until water remains clear. Need to empty and refill water a few times. Pat dry with absorbent paper. Re-install head and cartridges and do a clean.
Dec 27, 2007 | Canon i80 InkJet Printer
Print wont print
Hello, You may check to insure the USB cable at the printer or at the computer is connected properly and didn't come loose by chance. Try disconnecting the USB cable from the computer, wait ten seconds then reconnect. This will let Windows "find" the printer again. Worse case scenario, you could delete the printer through device manager, reboot you computer and Windows will "find" the printer and reinstall the driver automatically on restart. Also check that the ink cartridge(s) is seated properly.
Jul 18, 2007 | HP DeskJet 3650 InkJet Printer
Deskjet 3845 not printing properly
it needs a proper service as the moving parts are not moving freely .. or maybe when installing the cartridge you have damagaed one of the sensors .. it can be one of both
Jun 25, 2007 | HP Deskjet 3845 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
177 people viewed this question
old marine
old marine
