Question about Saeco Incanto Classic Espresso Machine
After getting Replace Water Filter VEntilate display I replaced with Saeco Intenza water filter cartridge I have always used. However, unit does not move off this display after I press OK button. I have removed & reinserted at least 3 times but noghting happens. How do I get unit to start up again?
  • 2 more comments
  • Jack Looney
    Jack Looney Oct 08, 2009
    What button? When you press the OK button it just switches to heating - rinsing but does nothing.
  • Jack Looney
    Should I just try reconfiguring everything? If so, how do I start complete reprograming? I can't get any coffee!
  • Jack Looney
    Jack Looney Oct 09, 2009
    Power outlet continues to work fine. I have the downloaded instructions from last year but can't find where it says anything about reacting to the Replace Cartridge - Ventilate other then reference to the "Aqua Prima"cartridge filter which I have never had. Tried finding window message about programming all over again and did not find. If you can steer me in right direction it would be appreciated - jack
  • Jack Looney
    I failed to indicate that I don't have the model your link refers to. I have the S-Class Incanto Classic. Also, I have thrown the switch on the back and then turned on again to no avail.
  • 742 Answers
Power OFF the unit while the error displays on panel lcd. After about 3 minutes, turn it back ON.
If this doesn't help, try removing filter. Power Off. Then power ON after 3 minutes. Device will display error. Now replace the filter and press OK.
Also, try to check if exhaust ventilating fan is working. This always causes trouble.
Posted on Oct 09, 2009
  • 10,865 Answers
Hello. I can assist you. First of all, in case you don't have one, here is the owner manual
http://www.espressotec.com/store/pc/catalog/saeco/sa1269_incanto_sirius_manual.pdf
Now. plug something else into the outlet to be sure that you have power there. Then make sure the main switch is in the on position. please let me know how you make out.
Posted on Oct 08, 2009
    President:
  • 1,653 Answers
After replacing the filter in the tank, keep the button pressed; when the indicator light is flashing, then release the button.
Also at times, the gears in the brew drive assembly will not complete the cycle to the proper start position for different reasons. Some of the reasons are:
  1. Brew group jammed or blocked.
    Note: A jammed or blocked brew group can happen when the brew group starts the cycle but doesn’t finish it.
  2. Either one of the micro-switches in the brew drive has gone bad.
  3. Brew drive motor failure.
  4. Broken teeth on either of the brew drive gears.
  5. Dirty brew group, covered by coffee grinds.
  6. Brew group or gears not lubricated.
  7. Connections to the board from brew drive assy., or motor have gone bad
  • Karl Wright
    Karl Wright Oct 08, 2009
    This is the Hot Water Button. Keep it pressed until the Filter Light starts to flash and then release it.
Saeco error: water circuit priming E05 Hi,could anyone help me with this problem? Vinegar didn't help...
Take out the water filter and see if the code disappears. If it does, replace the water filter. If not then use vinegar to descale the unit.
Dec 17, 2015 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Incanto S Class rondo I think it is an older version as very manual no computer. It has a flashing red light on left side (where coffee comes out) it has a ~~ on it. The machine still...
That light indicate that you need to change the water filter in the tank. The water filter is either an Aqua prima
or intenza filters. If you are not using the filter I would suggest to just reset the light. You can reset the light by holding down the water button under the coffee brew button. Looks like a water drop.
You can also download the manual at www.CeriniCoffee.com
Apr 11, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Why in my saeco VENTILATE message comes? Also grinder is working continuously why?
On grinder it might be set too fine...
On ventilate, there is an air lock in the hydraulic system, run the hot water cycle for a few seconds to clear.
Jan 12, 2011 | Starbucks Saeco Italia Digital Barista...
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Ventilate shows, nothing works
There is an air lock in the hydraulic line of the machine, thats why it is calling for ventilate, if hot water valve is open and it is still calling for ventilate, then it is possible that the valve is blocked, it might be at top of the wand or at the tap rod assembly.
Jul 28, 2009 | Saeco Royal Professional Espresso Machine
My saeco s-class incanto sirius machine keeps say replace water filter & ventilate even after I replaced filter
Sounds to me that water is not getting to the pump. Try charging the water filter before using by letting it sit in some water for about 5 mins.
Jul 23, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Fill Water tank - Ventilate
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Aug 23, 2008 | Saeco Incanto Classic Espresso Machine
New Royal espresso machine
It means you have an airlock in the water system. It can occur when you refill the water tank also.
Quite often you can run the hot water nossle untill the airlock clears. You will hear it splatter and then it should be sweet to go.
Jan 25, 2008 | Saeco Royal Professional Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
251 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
