NO POWER RECENTLY MOVED FROM ONE LOCAL TO ANOTHER. TRANSPORTED ON FRONT SEAT OF SUV. SET UP IN NEW PLACE AND TRIED TO POWER ON BUT IT ONLY CLICKS. PLUG AND UNPLUG AS PER MANUAL BUT TO NO POWER. ANY IDEAS / SUGGESTIONS?? THANKS, MICHAEL
    Scholar:
  • 131 Answers
I know this might sound strange, but there are 2 power buttons on some Yamaha recievers. Power and Standby buttons. The power button is very small and located 7 o"clock in comparison to the much bigger stand by button. Once you turn your power button on then try hitting the main power up off the remote & see if that does it.
Turk_97
Posted on Oct 09, 2009
Transporting a Kenmore front load washer and gas dryer
Yes you can lay them down. Some modals call for 24 hour reaping time before you can plugin to run. Reaping meaning some modal have the new R134A coolant in them so if they lay down wait 24 hours before use. Gas you can just lay then down and brace it so it can't move around.
Aug 02, 2016 | Kenmore Washing Machines
Seat belts are locked in 2002 ford expedition
there is a pretensioner in the seat belt buckles that go off when the air bags go off
Jun 12, 2012 | 2002 Ford Expedition
How hard is it to remove the seat for transport in a SUV
jim not too hard unless its not been removed in a while. Unplug the joystick cable running to the rear of the chair pull up the seat release lever usually on the right side of the seat and twist and lift up on the seat at the same time hopefully the seat will lift right off. Now before you try all that remove the headrest from the rear seat and lift up on the seat adjustment lever and fold the seat back forward as far as it will go. Measure the heigth of the chair in that position and measure the heigth of your SUV opening if it is 3-4 inches lower then the chair should fit without having to remove the seat. You could also unscrew the armrests where they go into the risers at the rear of the seat and lay them on the back of the lowered seat back and drive the chair into the SUV using a ramp. This used to work for me when loading into a Jimmy SUV Hope this helps you
Nov 18, 2010 | Pride Jazzy Select 6 Indoor Power...
How to lower the seat for transport
Mur What are you putting the chair in to transport? If it is a van then you can move the seat back forward or backward (using the seat back release lever on the chair) enough to get it in the van or SUV. I used to transport them in a 98 Jimmy but had to tilt the back all the way back to get it in. Lowering the seat I don't think will give you enough clearance to do that cause it will only lower about 3 inches. Hope this helps
Oct 08, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Hi i recently brought a sharp arm 276 in denmark and transported here to london to give to a local charity. upon recieving it i plugged it in and afterpowering up it says on the display contact customer...
The L1-00 error code deals with the scanner not moving. Look to see if the scanner is not locked in place. Most of the time when a copier is moved they may lock the scanner down.
Apr 01, 2010 | Office Equipment & Supplies
2001 Volvo V70 drivers power front seat will move forward only.
if you hear a clicking sound from under the seat when trying to move backward then its not the switch. check the motor instead
Jun 02, 2009 | 2001 Volvo V70
Whirlpool washer
im going to assume its a front loader. try opening the access panel by removing 3 screws along bottom front of unit. give a look inside, there should be 4 suspension/shock absorbers holding drum form shifting.If disconnected the just "snap"into place with quarter turn into holder.while under there the pump is located right there in front, open the "button trap" front of pump see if perhaps theres something inside pump housing making noise
Mar 11, 2008 | Washing Machines
Hitachi 53sbx10b
Try the auto convergence feature of the TV. Press the button on the front of the tv and wait about 5 minutes....
Apr 27, 2007 | Hitachi 53SBX01B 53" Rear Projection...
96 people viewed this question
 Grubhead
Grubhead
