Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Craftsman 16hp B&S, 42 tractor. engine surges, blows oil
I have a Craftsman 16hp B&S, 42 tractor. model 917.270680. Last week when I started it, it ran rough, and wouldn't speed up. I engaged the blades and the engine ran rougher and slower until it conked out. It would not restart. I checked the oil and it had the vicosity of water and smelled of gas. Took off the air filter and there was gas/oil in the bottom of the filter housing. Put on a new carburator (and fresh oil)- it started immediately, but then it started surging up and down and the govenor lever cylcled back and forth searching for a steady state. The crankcase ventilation tube is pushing out a lot of oil & air into the filter housing-even after 15-30 seconds. Also have occasional backfires up the carb and out the exhaust. Smokes at time. What is my next step? Do I have a broken piston ring? I have not checked the compression or the adjustment of the govenor.
  • 472 Answers
SOUNDS LIKE YOU HAVE A AIR LEAK AND SOME BAD GAS AND YOU MAY WANT TO CHANG THE OIL 1 MORE TIME LETME KNOW IF THIS HELPS IF NOT ILL DIG IN TO IT WITH YA
Posted on Oct 08, 2009
How much oil does the engine take for an oil change
Briggs & Stratton engines typically take 48 ounces of SAE 30 oil.
Kohler engines typically take 64 ounces (2 quarts) of 10w30 oil.
Always refer to the dipstick to ensure proper amount is added and do not over fill.
Apr 24, 2016 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Does Craftsman Model 917.272461 have a low oil shut down sensor?
Sounds you added oil for late. Can you turn engine by turning engine
on the screen, top of engine?
Aug 26, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftman 917.270.711
check to see if the oil smells like gas the needle valve in the carb doesn't seat and gas drains into the engine the oil gets thin and burns it fast
May 30, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman garden tractor Mod # 917.257740 blows main fuse.
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Jul 06, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Won't start after running for some time
check the oil in it some of the new mowers have a low oil shut down switch on them so engine doesn't blow up the other thing you can try is sprying carb. clean in carburator try these & let me know , wade
Jun 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman lawn tractor 21.5 hp, model no. 917.272463. The engine starts well, but while running it spits and sputters every second or so, whether at idle or at full throttle. I changed the fuel...
Try changing the its oil-seals. The problem lies there. It may be damaged or the oil-seals are now smaller than its is used to and it is because of the heat. The oil-seal are rounded things that are made of rubber.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor turns against its self
Sounds like the flywheel key may have started to shear and changed the timing. pull flywheel and check key.
Mar 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need help to reinstall the under mower 42'' unit that out
I have that manual. If you want, give me a postal address and I'll mail you a copy. Mac
Nov 13, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
616 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
