Question about Whirlpool GU2400XTP Built-in Dishwasher
Will not drain after final rinse - Whirlpool GU2400XTP Built-in Dishwasher
  • 68 Answers
Check inside the dishwasher and clean out filter screens then Check the drain line between the dishwasher and sink for clogs. If all clear then the pump has gone bad or shorted out and the pump will need to be replaced.
Posted on Oct 08, 2009
Hobart SR24H dishwasher after rinse cycle the same time pampas water in and out of the dishwasher, two pipes are opened and working
Hello.
As per my personal opinion this is normal because for the final rinse you have a small booster or boiler..
When you turn on the machine..it starts fill and also the booster for the final rinse.
You start the machine..wash cycle...rinse cycle..
Now..new water(from rinse booster) is coming on the tank in order to rinse the dishes..on the same time the machine drains the excces water from the rinse(over flowing) and fills up the booster with new water.
Should be like this
Good luck
Jun 29, 2013 | Dishwashers
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
SOAP NOT RINSING OUT OF FINAL RINSE. CHECKED DRAIN NO OVER FLOW OF WATER THIS IS A WHIRLPOOL NEW WASHER
sounds like a case of over soaping especially if your water is soft. this is usually a front loader problem but..
Epsom salts added to the final rinse usually does the trick as it breaks down the oxygen loaded foam.
Very common problem in Launderettes.
Feb 21, 2010 | Amana ALW480DA Top Load Washer
Washer won't rinse & drain
The lid wasn't locking in all the way- when we put something heavy on top of the latch it started working.
Sep 15, 2009 | Whirlpool Washing Machines
Front load washer, will not do final rinse
A lot of times it is the strainer clogged at the pump. Hope that helps.
Sep 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washing machine stops after final rinse cycle
Your lid switch is bad. It must be replaced.
Jun 26, 2009 | Whirlpool Washing Machines
Clothes still wet after final spin
Possible timer or drain problems.. ok.. when your washer is in rise.. before it goes into final spin.. it stop agitating, then drain water for about a minute or two.. listen to see if stop drain for a sec, then began to spin... when it come to draining.. make sure that you hear all the water flow out of your washer.. sometimes when you have a slow drain.. that can do it too.. but the first possible is likely.. good luck
Jan 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore dishwasher
The water that remains after the final rinse is normal and serves to keep the seals lubricated. This is a normal function of the dishwasher.
Jun 08, 2007 | Kenmore 17259 Free-standing Dishwasher
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Whirlpool GU2400XTP Built-in Dishwasher Logo
167 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
