Question about Motorola Mobility W375 Cellular Phone
Truns off evrey 60 seconds
New phone first try, it restarts it self evrey 45 to 60 seconds or so ... full battery charge ... when it shoutdown you can restart it pressing on-off button. losing (obviusily) what you were doing.
  • 46 Answers
Try to remove your sim card and clean the contacts with an eraser. Reinsert the sim and all should be fine.
Posted on Dec 24, 2007
Motorla bgb ce0168 will not trun on why
Does it do anything when you try to power it up? Are you sure the battery is holding a charge? If the battery power level dropped below a certain point the charging system must be reset.If the reset works make sure you use a wall charger and not a computer USB jack to charge the unit If it happened because of a battery charging issue it will recognize it is on a usb jack and will shut down forcing you to do the restart once again. Once the battery is over 10% the problem should not return.
You can try a forced restart ,
Press and hold Volume Down + Power for 10-15 seconds and your phone should power all the way off. Then, power it back on as you normally would.
Some of the new electronics line require a reset of the LIon battery charging system and must be done by the dealer.
GOOD LUCK. I hope this helps take care of the no power issue.
A quick tip for many kinds of electronic issues is as follows.
Here is a little trick to try if you can get the battery out.Once the battery has been removed put it to the side ad wait a few minutes. After waiting and without putting the battery back into the unit hit the power on switch several times. This uses all of the reserve stored power in the unit and acts as a main system reset.This will work on many types of electronics.If you ever had to take any kind of electronics in for repair and when you get it to the repair facility the problem has corrected itself.this is what this action is trying to accomplish.
Dec 04, 2014 | Vehicle Parts & Accessories
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Jul 20, 2014 | ASUS MeMO Pad HD 7
My phone wont turn on after restart what do I do?
Remove the battery for 60 seconds, reinstall battery and try starting phone. Make sure the battery has a charge.
Dec 31, 2013 | T-Mobile Prepaid Alcatel One Touch Fierce...
3g won't trun on
My Dear Please try it;
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 03, 2012 | Samsung Dart T499
I am using nokia x3. it is showing charging notification when charger is plugged in but it is not geting charged....plz help....
as i know sure its also some times show the battery full and after switch off by him self or after few seconds tell it very low .so just buy new origin battery and dont charg it until became low to save it for long time
if you need more explain please comment
Jun 09, 2011 | Nokia X3 Cell Phone
Dose the vivitar vivicam 8025 have charge befoe u can trun it on it brand new and wont trun on can u help me please
most camera are sold with "flat batterys" in them (its a fire hazard thing) so you need to fully recharge the batterys before use or the camera will just turn its self off,,,look at the hand book for charge times? dont try using it on half charged batterys you only kill off the battery that way,,,
Aug 10, 2010 | Vivitar ViviCam 8025 Digital Camera
Will not power on. ive put in new aa batteries
Try this:
- remove the batteries
- wait more than 60 seconds
- reinstall (fresh/charged) batteries
Mine was exhibiting the same problem ... it would start to power on, but died as soon as the lens began any motion at all. It would power up fine on AC power, or on the dock. I was going to install new firmware on the camera to try to fix the problem. Reading the firmware installation instructions indicated that, to complete the firmware upgrade, the batteries would need to be removed for at least 60 seconds, which I'm guessing forces the camera into some sort of deeper reboot/restart.
Apr 12, 2010 | HP Photosmart 735 Digital Camera
Even with fully charged batteries, the camera won't turn on. what can i do?
Try this:
Mar 14, 2010 | HP Photosmart 735 Digital Camera
When I power on nokia 6600 only white screen for 45 seconds and
CAUTION: if u have any valuable data on ur phone plz dont try this .
first charge ur battery until its full
next switch ur phone on while pressing the green key ,the 3 key and the * key.
hold these till a screen saying 'formatting' comes
allow it to format
it may take 5 mins
dont remove battery or phone system will bcome corrupted
Oct 19, 2009 | Nokia 6600
I can't call or be called!
I had a similar situation happen, but it self fixed its self.
I could receive calls but not hear the person.
I knew it wouldn't dial out because if you watch the display as the call is being placed, you would notice no second touchpad "speaker phone" option would appear like normal. YMMV
I also have a key pad (certain letters only) button issue.
I did chuck the phone in the trash, but later retrieved it and it slowly had functions come back. (I suspect drying out from moisture, beer in the trash.........)
It has seemed to have a battery issue with the older battery (I bought a new one and cycle between them on occasion.
>>> I suspect this is your issue a battery going bad, showing decent battery life but quickly croaking.<<< try a new cell.
It does have some memory issues if the SD card is full and the internal memory is used by photos and videos. So I keep the internal phone memory clear or 1/2 full.
I use the base charger to condition the battery and charge slowly over night.
Try the battery in your case.
Jul 24, 2008 | Palm Treo 650 Handheld
Motorola Mobility W375 Cellular Phone Logo
26 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
