Question about Garmin nuvi 350 GPS Receiver
My garmin nuvi 350 is locked onto: "Do you really want to erase all user data?" I've tried resetting...what to do...I press NO and it highlights YES and nothing happens..just locked.
  • Garmin Master
  • 2,130 Answers
Your touchscreen is jammed or defective and is telling the GPS that there is pressure on the touchscreen constantly in that area. It needs to be replaced. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Oct 08, 2009
How can i reset my garmin nuvi 780
The following solution is available on Fixya:
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings.
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mod.
Sep 02, 2011 | Garmin nuvi 780 GPS
If I found a garmin nuvi gps it got a locked on it how can I reset it or something
Most GPS navigation devices from Garmin has a reset function which allows user to access a Maintenance Mode screen with system information, diagnostic details or perform the reset function to restore Garmin Nuvi or other series unit to its original default factory settings.
Depending on which model of Garmin GPS unit you're using, the following routine can reset the Garmin device to original factory loaded settings, or bring up the Maintenance Mode with access to System Information and View Diagnostics screen, where users can see various logs, and of course, clear all user data (reset to factory defaults) or clear Waypoints.
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Hack above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Trick above works on Garmin nuvi 200, 250, 360 750, 760 series unit. In fact, there is a video demo by user of Garmin Nuvi 360 on how to perform the hidden reset function.
Hope helps. (remember to rate and comment this answer).
May 19, 2011 | Garmin nuvi 255W GPS Receiver
My Garmin will not power up. We have hooked it up to the usb cable to our computer and it still does not come on
try entering maintenance mode~~
~~ http://www.mydigitallife.info/2009/06/09/how-to-reset-garmin-nuvi-gps-device-access-maintenance-mode/
Mar 07, 2011 | Garmin GPS
My garmin nuvi will not shut down. The screen is white. Is there a reset button on the unit?
In some nuvi models there is a reset button.But in some nuvi models there is no reset button.you have mentioned only garmin nuvi but not mentioned the model of the garmin nuvi.But still i will mention the reset button location of some garmin nuvi models.Hope that helps you.
The reset button/procedure for garmin nuvi models
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin nuvi 200, 250, 360 750, 760 series unit. Garmin Nuvi 360 on how to perform the hidden reset function.
Reset button on the bottom of the nuvi backside.
Click on the link below to get the exact location of the reset button.http://www8.garmin.com/manuals/1512_SetupandGo!.pdf also check out this link too http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf Thanks. keep updated for any more query.you can rate this solutionand show your appreciation.
Jun 11, 2010 | Garmin GPS
Garmin 255w locked
Hello :
Try hard resetting . That should solve the problem .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 14, 2010 | Garmin nuvi 255W GPS Receiver
GPS is disabled
1:Turn the Nuvi on.
Apr 14, 2010 | Garmin Nuvi 350 Car GPS Receiver
My Garmin Nuvi 205 gives the wrong direction, how do I reset it?
To reset your NUVI , please follow one of these procedures :
1:Turn the Nuvi on.
Apr 14, 2010 | Garmin nuvi 205W GPS Receiver
I forgot my pin on garmin 205
Try this. You'll lose all your favorites and anything else you have entered though.
Dec 20, 2009 | Garmin nuvi 205 GPS Receiver
I have a Garmin 396 that I use for aviation navigation. The 396 just suddenly became unable to find the satelites and therefore will not function. I tried to rebook by unplugging the battery for a couple...
I recommend either resetting the device or update the software. You can find software downloDepending on which model of Garmin GPS unit you’re using, thefollowing routine can reset the Garmin device to original factoryloaded settings, or bring up the Maintenance Mode with access to SystemInformation and View Diagnostics screen, where users can see variouslogs, and of course, clear all user data (reset to factory defaults) orclear Waypoints.
Power off Garmin unit. Press on continuously the uppertop left corner of screen and then power on the unit by pressing onceon the Power button. You should be prompted to clear all user data, orasked if do you really want to start up in maintenance mode. Press“Yes” to reset (warning: all data will be erased and lost,so backup before proceeding) or enter maintenance mode.
Turn off Garmin device. Press down on bottom rightcorner of the touchscreen, and then power on the GPS unit. You shouldbe prompted whether do you really want to erase all user data, or askedif do you really want to start up in maintenance mode. Press“Yes” to reset (warning: all data will be erased and lost,so backup before proceeding) or enter maintenance mode.
Trick above works on Garmin nuvi 200, 250, 360 750, 760 series unit.In fact, there is a video demo by user of Garmin Nuvi 360 on how toperform the hidden reset function.
Note: If entering maintenance mode, it’s also possible to perform master reset by selecting clear user data option.
Once the device has been hard reset, user have to perform the set upprocedure again upon start up. Note that erase user data command onlydelete data in the Garmin unit’s memory that isn’taccessible to the user when the unit is connected to computer. Thecommand does not erase .gpi or .gpx files loaded (if your .gpx filescontain any waypoints then they will automatically be imported intoFavorites), nor will delete any MP3 music, JPG photos or any otherfiles that have been stored on the GPS memory card.
Once the Garmin GPS unit is reseted, remember to place the deviceoutside where there is a clear unobstructed view of the sky for 15– 30 minutes in order for it to requires fix to GPS satellites.
Unfortunately, even if you perform master reset on Garmin GPS unit,it does not reset Garmin Lock security feature, which password-protectmost Garmin electronic devices to deter theft. If you forget the PIN orpassword unlock code to unlock the Garmin unit, the best solution is tobring it to Garmin to get unlocked. “Secure Location” doesnot unlock a locked Garmin unit either as it’s only a temporaryfix as when it’s turn on outside the security location, thedevice is locked again.
ads on the manufacture's website.
Nov 15, 2009 | GPS
My garmin nuvi works as a stand alone, but plug her in to computer or car power and all you get is a screen showing garmin logo and a picture of it connected to a computer.
Hi
You will need to reset your Nuvi as it is locked into computer mode. To reset it - depending on your version see below.
On some Nuvis there is a recessed master reset button on the body of the unit which you need to access with a nib of a pen or bent paper clip.
For Nuvi 660/680 series
Power off Garmin unit. Press and hold the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
For nuvi 200, 250, 360 750, 760 series
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and while holding it power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
If the above fails it is likely that the problem is not with the Nuvi but the charging unit which is not signalling the unit properly and the Nuvi is recognising it as a USB cable instead of a charger.
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 19, 2009 | Garmin GPS
Garmin nuvi 350 GPS Receiver Logo
51 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
