Question about Ricoh Aficio CL3500N Laser Printer
RESET PCU ERROR FOR COLOR PHOTOCONDUCTOR UNIT.
RICOH AFICIO 3500N RESET PCU ERROR FOR COLOR PHOTOCONDUCTOR UNIT. KEEP PULLING IT OUT AND RESETTING BUT ERROR KEEPS COMING UP. FIRST HAD A PAPER JAM AND CLEARED THAT, USED CANNED AIR TO CLEAR ANY DEBRIS AND TONER IN PAPER PATH, PAPER JAMS RECURRED. OPENED PRINTER AND PULLED THE PCU'S TO SEE IF ANY PAPER IN THAT PATHWAY, WHEN I PUT THE PCU'S BACK, AM GETTING THIS ERROR. COULD IT BE TONER DUST ON THE CONTACTS?
lolita
  • 385 Answers
SOURCE: Error message says reset PCU correctly
You get this message because the PCU isn't seated properly. This is a link for the user manual for this printer: http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf On page 13 shows a diagram that indicates the photoconductor unit on the printer. Page 60 shows you different error messages, what they mean and how to fix it. It means you have to take out the pcu and reseat it into the printer, it is not in correctly. Page 29 shows you how to do this. It has pictures of how to take out the pcu and put it in correctly. I hope you get it fixed.
Posted on May 12, 2007
  • 58 Answers
SOURCE: Ricoh Aficio CL3500N PCU issues
These machines were actually made by Panasonic and they eat PCU's there is no rhyme or reason, they just do. I would replace all of them as soon as possible. These printers were pretty much interim technology for Ricoh until they developed thier own engine. I highly recommend the new 400 color series, low cost per page, vg color and consumables last a long time!
www.mfpsolutions.blogspot.com
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
  • 58 Answers
SOURCE: ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
Cogz
  • 1326 Answers
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Posted on Jan 25, 2009
  • 990 Answers
SOURCE: Installing PCU on Ricoh Aficio MP2510.
Hello sir; The procedure little bit difficult, Remove PCU, remove the front cover(two screws), remove the rear bushing by remove one lock ring, remove the front joint, remove the developer hopper cover( 3 hook ) dump the old one out vacuum entire unit ( magnet roller ), fill in new developer, replace hopper cover, after replace PCU and developer you need to do some simulation, #1, press "clear mode" "107" and press hold "clear/stop" for 3 seconds, then touch screen on "copier sp". #2, enter sp3902-9 to1 for black drum unit, sp 3902-10 to 1 for yellow, sp3902-11 to 1 for cyan, sp3902-12 to 1 for magenta, #3, enter 3902-005 for black, 3902-006 for yellow, 3902-007 for cyan, 3902-008 for magenta, set 3902 to 1 for each of these if replaceing developer, press "exit" twice to end the service.
Posted on Sep 18, 2009
I have several of these ricoh 1515 copiers all working fine and then posting a need photocunductor error. Is this some preset error that comes after so many copies like HP got sued for or is the...
Hi, the "Replace Photoconductor" message does come up after a preset number of copies, typically about 60,000. The photoconductor will still continue to work fine, and even with the message displayed the copier should run like normal. The message will keep flashing until you replace the photoconductor, and then it will automatically detect the new unit and the message will disappear.
Jan 21, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Jun 23, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
How to replace image unit ricoh aficio 220
Do you mean the photoconductor unit? To replace the photoconductor (PCU), open the front cover and the right side covers (the duplex door and the main side door). The PCU sits to the right of the toner bottle -- it is a black unit that has the blue cylindrical drum facing the right side of the copier.
On the upper left side of this unit is a ridged tab. Push this tab in and slide the PCU all the way out of the machine. Open the box with the new PCU and remove all of the tape and paper, then slide the new PCU in where the old one came out of. When you shut all of the covers, the copier will recognize the new PCU.
Apr 23, 2010 | Ricoh Aficio 220 Laser Printer
On a ricoh aficio 3500n color laser printer getting a replace black cpu error after changing the black cartridge. How do i take care of this?
replace the black pcu(drum unit).
the life of the pcu(s) are 15k each(blk & col) .
the machine will work but copy quality will reduce and the error will be there.
replacing the cartridge has nothing to do with this error.
Jan 14, 2010 | Ricoh Aficio CL3500N Laser Printer
How do I replace photoconductor?
turn off the machine.open the front door. open the right door. remove the toner hopper. after the hopper is removed , remove the pcu connector. on the old pcu s a push tab. push the tab with your right thumb and pull the old pcu out. unbox new one. pull all tabs and paper off new one and install. put toner hopper back in. close all covers and turn on machine.
Dec 31, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
AFTER PHOTOCONDUCTOR REPLACED PAGES ARE BLANK
IF you replaced the entire PCU, make sure you pulled the plastic tabs from the unit and removed the protective paper from the drum area. I don't remember if the new PCU comes with developer pre-installed.
If you replaced the drum/developer, it is common for the lower developer unit drive gears to wear down and break off some of their teeth.
Hope this helps.
Jun 30, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Resetting the photoconductor unit
After replacing the PCU, you can clear the counter by going to Clear mode, 107, push and hold Clear/stop. Screen should change. Push Copier, 7804 should clear drum counter.
Jun 28, 2009 | Ricoh Aficio 450 Copier
Paper jam leading to error code sc440-01
I think the code is a black pcu motor lock. Replacing the black pcu might fix it, but the black waste toner section could be backed up.
Jan 29, 2009 | Ricoh Aficio CL7200 Laser Printer
RESET THE PHOTOCONDUCTOR
you need to deactivate the pcu alarm.for a detailed explanation let me know if you still need to know how to do it
Mar 13, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio CL3500N Laser Printer Logo
510 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
