Question about HP Computers & Internet
Hello we have a 19inch HP monitor that doesn't power up, even with a new cord and different outlets in the power strip.
  • 81 Answers
After connecting it to the circuit correctly> try pressing the power button that might be either on the right top or side> if the power button doesnt turn blue> the monitor has gone bad
Posted on Oct 10, 2009
Hp color laserjet cp1215 wont turn on
try a different outlet, especially if you are using a power strip. Sometimes even one outlet in a strip can fail. Not sure how farther you tried other than check the power cord. If other devices work on the same outlet hole you plugged you machine into then, try another power cord. If that does not help then you will need to seek a tech.
Nov 07, 2012 | HP Color LaserJet CP1215 printer...
My nc6400 won't power up even when connected to a power adapter. How can I fix this?
Since you already tried another power cord (assuming that it was a working cord and for the exact same model). Then I would say your motherboard is dead.
Aug 17, 2012 | HP Compaq nc6400 Notebook
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
Hello: Just recently, the 2159m HP monitor goes to sleep in the middle of an activity. This happened on two desktops and different settings. Repalced the video card, adjusted settings, replsced DVI...
Check the cord and connections for the monitor; this has one wire that must have voltage on it or the monitor goes to sleep, and a broken wire or loose connection will fool it into thinking you are powering down. If this doesn't work try going into power options and setting monitor to never power down.
Jan 22, 2011 | HP 2159M Monitor
The monitor will not come on. We tried different power cords but no luck.
john855, Need to know model and "date of manufacture" from rear of unit to provide you with some help. Is unit LCD or CRT type of display? Is unit powered by a wall outlet or is it connected to a multi outlet "power-strip" ?? 12fixlouie
Sep 27, 2010 | Orion Computers & Internet
When i cleaned my dell demension i put everything back exactly how it was now when i turn on my computer none of my external devices mouse pc screen keyboard is not turning on i need help
I would first check and verify that the electrical outlet or power strip that they are plugged into is working. If a plug gets in a bind it could have blown a fuse on the power strip or the power strip might have a reset switch on it. Or the power strip might have failed. If you have a uninteruptable powersupply that you plug everything into you will need to confirm that it is working as well, test it and look for reset buttons or a fuse holder on it. Your electrical cords could have been pulled out from the wall outlet itself while cleaning sometimes even wall outlets if put in a bind from pressure will blow a fuse or the cord might pull out just enough that it is not making a good connection.
You might get a lamp with a bulb that you know works and plug it into the same electrical receptical that you have the dell computers power cord plugged into and then test the monitor power source the same way.
If the outlets or power strip are getting power and that is confirmed by testing them, and then you plug in the Monitor and Dell power cords into the sources that you have confirmed are getting power, and they do not come on we have a different problem.
If the monitor is hooked up wrong to the computer or not even hooked to the computer the light should come on on the front of the monitor incicating that it is getting power. If you plug it into a confirmed working electrical outlet the light should come on on the power button of the monitor. If it does not come on then somehting might hve possibly damaged all of the epuipment that was plugged in like a power spike on the electrical lines going into your home, this would be very rare but not impossible.
I am sorry for all of the senerios but you were not really clear on what you were using as power sources going to the equipment and I wanted to try and cover the most common possibilities in one email. Please let me know if this helps
Aug 02, 2010 | Dell Dimension E521 PC Desktop
The box want come on
Make sure power cord is plugged in all the way to computer. Next, plug the power cord into a different outlet. If you have it plugged into a power strip, verify the strip is ON. Was computer hit by lightning etc?
Oct 21, 2009 | HP Computers & Internet
No Power
There is a whole lot the typical user can check but here is the list: -Disconnect the power plug from the power strip and plug directly into a tested wall socket. Sometimes the power strip sockets go bad. -Try another working power cord. -When you plug in the power cord do any of the monitor LEDs com on?
Jul 29, 2007 | HP vs19 (Silver) 19" LCD Monitor
Computers & Internet Logo
65 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
