Question about Gateway GT5220 PC Desktop
Power switch does not work, what do i need to do?
  • 68 Answers
Replace the power pack for the PC...not very expensive and easy to do. Just make sure all power cords are unplugged.
Posted on Oct 08, 2009
Odyssey power window switch
You will need to start with removing the drivers side interior door panel. You will need a test-light and check for power and ground at both the suspected switch and the window motor. At the switch, test for power and ground going into the switch. Then test he other side for power and ground going out. Test for power and ground at the power window motor too.Please write back with what you have found and write back, good luck.
Mar 08, 2014 | Cars & Trucks
Patton space heater power knob isn't working
First thing check see if you have power going to switch with a multimeter if you have one if there's power going in it switch need new switch probly you can us your multimeter to test switch on ohms
Mar 01, 2013 | Heating & Cooling
Driver side window stopped working
most of the time driver side windows switch be the first switch to wear out.try removing window switch work switch while moving the wires see if window try to go up, if yes, window switch broken.if switch not broken check see if power going to window motor when you work the switch you need a test light or digital volt meter to check to see if power going to power window motor.if power going to power window motor, either window binding or power window motor faulty. make sure driver side window master switch not locked out.if no make sure all the other power windows work if not you have blowed fuse.
Nov 26, 2012 | Hyundai XG350 Cars & Trucks
I'm working on a 97 geo prizm and need to find the ignition relay,I rplaced the ignition switch and have no power getting to the switch,there is power at the harness and I can bypass the switch an
If you can jump it at the switch and get it to start, then the ignition relay must be working. It is hard to tell from your post but I think you are using power from another source to do this? I am thinking you have a blown fuse on the wire the furnishes power to you ignition switch.
Feb 12, 2012 | 1997 Geo Prizm
Passenger side window will not roll down need to know what fuse to check 1993 Honda del sol
The two windows are fed off the same fuse. If the drivers side works than the fuses are good. What you will need to check is power On the orange wire at the passenger side switch. If there is power than the switch or motor may be bad. I can give you more info on how to determine which if needed. If there is no power than you will need to check for power on that wire on the drivers side. If there is no power there and the rear window works than you have a bad master switch. If there is power there than you have an open circuit in that orange wire between the two switches. Most likely in between the door and the body where the door harness goes through. If there is no power on the orange wire on the drivers side switch and the rear window does not work also make sure that the window lockout button is not depressed. This will turn off the power supply to those two switches. If the switch is not off than the master switch is probably bad. Let me know what you find. I will be more than happy to help if you have any more questions.
May 26, 2011 | Honda del Sol Cars & Trucks
Power windows stopped working, 30a maxi fuse replaced didn't help
Check the drivers side window switch for power, and check that it sends power to other windows when pressed. If no other switches work and the driver switch has power and ground it needs to be replaced. It feeds all the other switches.
Mar 13, 2010 | 1999 Ford Explorer
Video switches but no mouse of Kbd on either machine
now are you using PS2 mouse and keyboards i presume if you are trying to use USB ones with adapters in it you need to put in power to the switch or they wont work as they need 5V to work. look on the back and it will tell you how much power it needs and get a transformer that gives you the same power or on you can change the power to that you need. hope that helps you
Sep 01, 2009 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
Power windows dont work at all,
WELL YOU NEED TO START AT THE BEGING YOU NEED TO SEE WHAT VOLTAGE YOU HAVE AT SWITCH AND MAKE SHERE THE DRIVER MOTOR WORK IF SHORTED COULD KEEP WINDOW SWITCH FROM WORKING HOPE THIS HELPS AND YOU NEED 12V GOING TO POWER WIRER THE WAY IT WORK IT POWER THLEG TO MAKE IT GO DOWN WHEN IT NEEDS TO GO UP IT SWITCH THE POWER LEG TO OTHERSIDE OF MOTOR AND GROUNDS THE OPISITE SIDE
Aug 13, 2009 | 2004 Chevrolet Impala
Windo motors wont work
The driver side window switch is the master switch, the power or input to either roll the window up or down goes thru that switch. Double check all the connections on the back of the driver side window switch are good. With a DVOM you can also check to see if 12v are even getting to the master switch in the first place. If you aren't even getting power to the main power window switch you could've blown the power window fuse.
Jul 17, 2009 | 1994 Oldsmobile Silhouette
Power switch will not power comnputer - does anyone know exactly what I need to fix this problem and where to order.
Presario power switch assemblies are only made for and sold by HP. If the manufacturer will sell you one (which I doubt) you will need to contact them at HP.com.
There is nothing unique about a power switch, any momentary on contact will work. Have you tried shorting the two pins to see if it is actually a switch problem?
May 17, 2009 | Compaq Presario 6350US (808736414036) PC...
Gateway GT5220 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
