Question about Maytag Dryers
Maytag electric dryer for months has taken about 3 times to dry a load of clothes now it has quit spinning
  • Maytag Master
  • 7,482 Answers
Sounds like you have a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Also you need to remove the back,
Sounds like your other problem is with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
Good luck,
I hope this helps
Posted on Oct 08, 2009
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
Maytag epic electric dryer takes a long time to dry clothes
check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
Nov 17, 2013 | Dryers
I have a neptune dryer I bought from a used appliance store about 6 months ago. The cycle comes on but there is no hot air. Clothes are not dry after 3 full cycles. I am not even sure if its gas. Don't...
you will need to get behind the dryer and disconnect the vent tube, try drying a load of clothes with the vent tube disconnected if it drys then the tube is the problem and needs to be cleaned out. If it is not drying at all then it is a few things, I am assuming its electric here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer takes too long to dry clothes. It could take up to 4 hours to dry a load of towels on high setting. What could be the problem?
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Oct 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Taking too long to dry clothes; it's been this way for a month or so; filter is clean; what else can I check?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My washer has been difficult to maintain balance when spin cycle is running for about a month. Also, the dryer has not been spining the clothes as dry as it usually did. Tonight, I put a load in and the...
You did not say what model washer you have. Top Load, Front Load and Model Number... That is very important.
As for the dryer..... If the washer is not getting a decent amount of water out of the clothes then the dryer could be becoming damaged continuing to use it. A dryer simply evaporates the water on tumbled clothes in it. It is is set on a TIME DRY setting, I doubt it will work at all. If it is set on AUTO DRY then, it could be running and running and destroying your dryer. You also may have a heating element that is weak or intermitently going on and off.
It is important to know how old, the brand, the model numbers of everything. Also if it is a Gas Dryer or Electric.
Sorry for the extra questions, but it is neccessary.
Kindly,
Jim
Dec 21, 2009 | Maytag Washing Machines
Dryer doesnt dry clothes
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer takes forever to dry clothes!
it could be the vent pipe is clogged. check that out too
Jul 05, 2017 | Maytag Dryers
Kenmore dryer only heats on delicate
I am not familiar with this particular dryer but most of the Kenmore family use different thermostats for different temperature. They are usually located in the rear and are clustered on the blower housing. Take the two wires off one thermostat at a time and test. It should be closed when cold if not replace it (Usually around $15 each) You probably have a very dangerous clogged exhaust. This will cause thermostats to fail. and can cause a fire. CLEAN It out and dont use flexible plastic duct pipe. The other cause of thermostat failure is if the washer doesn't spin properly and the clothes are too wet when dried. A properly operating dryer will not take much longer than 45 minutes max to dry a load.
Jun 14, 2008 | Dryers
Dryers Logo
49 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
