Question about Sony KDSR50XBR1 50" Projection HDTV
Sxrd 50 won't turn on - Cooling system or dlp lamp?
Sxrd 50" won't turn on. Green light flashes as if it is going to (sound like fan starts up as well), then shuts down and red light flashes 4 times repeatedly. Does this sound like the cooling sys or the lamp?
  • 556 Answers
4 blinks is a fan error, check and see if the fans are clogged with dirt. Unplug the set then take the back off and get some canned air and blow the fans out.
Posted on Oct 08, 2009
Testimonial: "Freakin' awesome. I was quoted $250 - 500 to fix this 'mystery' issue. $6 at office depot and it's fixed! You Da Woman TVTECHLADY!"
Solid green light but no picture
I think this is a projection set. Sonys are called SXRD type lcd projection . Little diff from DLP types. But they do have a lamp. Unplug set plug back in then turn on . Count blink code. Check lamp also. blink code is 2 digit code. Code will give clue to failure.
Oct 01, 2013 | Sony KDF-E42A10 42 in. LCD Television
Changed lamp and fan and still have a flashing red light
changed my lamp on my 50"grand Vega and got one or two flashing red LEDs
forgot to put the lamp cover back tried again everything is fine now thank god,
Jul 19, 2012 | Sony XL-5100 Projector Lamp for Grand WEGA...
On my 50" sony sxrd
The service manual lists 3 blinks as the light cover not being secure. it has a micro switch behind the cover so if you hold down the switch you can see if this is the problem.
Apr 16, 2011 | Sony KDS-R50XBR1 50" HDTV
60" Sony SXRD that won't turn on
Sounds like the line output transformer (flyback transformer) has gone out.Depending on how old the TV is will depend on if it is worth fixing
Nov 14, 2009 | Sony Televison & Video
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Oct 29, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
825 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
