Question about Microsoft Xbox 360 Console
Disk wont spin?
Whe i put a game into my 360 it reads on the screen unplayable disk. i open the drive and the disk is in the same direction that i put it in as what should i do?
  • Anonymous Jul 25, 2008
    mine will not spin at all and the red ring of death is flashing ineed help because i don't know what to do.
  • Anonymous Apr 20, 2009
    I put a disk in and it wont spin it
  • 4 Answers
If its still under warranty, and the seal hasn't been cracked, contact Microsoft.
Try what hijackthis1 suggested, if that doesn't fix it, try this.
Since you have the 360 apart, and the top cover off of the dvd drive, here we go...
There's a circular cut-out that's glued to the top cover that you removed from the dvd drive, right below the sticker with all of the drive information. I was able to pop out the cut-out. After that you now have (3) pieces in your hand, the cover, cut-out, and a plastic piece.
Connected the dvd drive back in the 360 with the top cover off.
Put a game or movie in the drive, don't hit the eject botton, just put the disc in the tray.
Now with the disc in the tray, put the plastic piece in the center of the disc. Its magnetic, so it should kind of lock in to place.
Connect the power/av cords in the 360 and turn her on.
You should see the disc try to spin. (It may spin once or a couple times around, but it will stop). When you see the disc start to spin, GENTLE, spin/turn the disc in the direction in wants to go. It should load the game or dvd with no problems.
Reassemble the cover and put back on the dvd drive.
Now use the eject botton, and try games and dvds.
If disc fails to spin, do process over again.
I've done this with one of my 360's with no problems.
The drive I used was an Hitachi 0059DJ.
Posted on Dec 25, 2007
  • 152 Answers
Open up the system and open up the CD Drive. Clean the lens of the CD Drive with some rubbing alcohol and a q-tip. Then put the console back together.
It only plays Normal Xbox games
The open tray and unplayable disc is because the lens isn't strong on the drive and needs to have a Pot calibration done to it to make the lens signal stronger. That should fix the open tray/unplayable disc issue. I have done this to quite a few drives and all have been working fine since.
Jul 12, 2009 | Microsoft Xbox 360 Console
Unplayable disk
Is this a used console. If it is someone changed the disk drive. The disk drive and motherboard are a couple. You need to flash your drive. To marry the two.
Jun 29, 2009 | Microsoft Xbox 360 Console
Unplayable disc
There is a good chance you DVD drive might have either a faulty motor or laser. In this case if you have any type of warranty you should use it but if you don't you'll have to purchase either a new XBox 360 or a new DVD drive.
The new DVD drive will not be able play games if you simply swap the drives. In order to have it play games you'll have to flash the old Key from the broken drive onto the replacement drive.
Either that or if your system is still under the 3 year warranty from RROD by Microsoft you can try to induce RROD on your XBox 360 and take up a claim with them. Most of the time they send u a refurbrished XBox 360 or a new one.
Jun 16, 2009 | Microsoft Xbox 360 Console
My Xbox 360 stopped spinning the CD and playing the games.
i myself have the same problem and currently working on it. go to youtube and type in "how to fix a broken xbox360 dvd disk drive" this guy is amazing and helped me out with the red rings of death. all u have to do is buy a new disk drive for about $50 and take some parts apart.
Mar 14, 2009 | Microsoft Xbox 360 Console
Xbox 360
You will need your dvd drive replaced. We can do this for you.
www.videogamerepairservice.com
Dec 30, 2008 | Microsoft Xbox 360 Console
Unplayable disc
Open up the console and open up the CD Drive. Clean the lens of the CD Drive with some rubbing alcohol and a q-tip. Then put the console back together.
Dec 24, 2007 | Microsoft Xbox 360 Console
Xbox 360
Sounds like you have a faulty DVD drive. If you are still in warranty Microsoft should either repair/replace the console, call them and explain the situation. Otherwise, if your warranty is out, you could replace the DVD yourself, there are many places to pick up the drives, ebay is a good place to start also xbox-scene.com would be able to help.
Please rate if at all useful, thanks!
Nov 29, 2007 | Microsoft Xbox 360 Console
Unplayable disk error and sometimes noisy
Go to Youtube and look up opening XBOX 360. There are lots of videos and tutorials explaining how to open up your XBOX. JUST REMEBER TO KEEP THE SILVER STICKER INTACT SO YOU CAN PUT IT BACK AND NOT VOID YOUR WARRANTY
Oct 07, 2007 | Microsoft Xbox 360 Console
Xbox 360 disc drive
To april23
what has most likely happened is that the magnet which holds disks in place has dis-lodged and is now stuck to the roof of the dvd drive. Unfortunately the only way to resolve this would be to open up the xbox 360 and open up the dvd drive to fix.
So if you're not confident at this or in doubt in any way I'd contact Microsoft first if it's still under warranty, if not then it's a case of opening up the drive yourself I'm afraid.
Note. Does the drive attempt to spin up when you put a disk in?
Or does it just make small noises then nothing except "open tray" on screen?
360 grinding noise and unplayable disc
Crack open the DVD case and see whats going on and try fixing it yourself. OR Buy a new drive off of eBay and transfer the firmware key over from the old drive too the new one.
Sep 20, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,826 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
