Question about Hotpoint Ovens
Hotpoint ew22 oven ......all working apart from oven , fan is on , no heat and temp light on front panel not lit
  • 1462 Answers
SOURCE: Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
Posted on May 06, 2007
  • 41 Answers
SOURCE: hotpoint dy46 x oven
Usually with ovens not heating up the element has gone and needs replacing. A few checks to do before going to the expense and trouble of replacing are to check the House Power Box Fuses to make sure none a blown - especially look for the one relating to the Oven or Range. If blown replace the fuse wire. If it blows again you have a problem with the power point or appliance. Does the Oven Fan work? If so chances are the oven is getting power as is the element and your house electrical lines to the Oven are fine and the element needs replacing. Not knowing the particular Brand you have amkes it difficult say how to remove the element. Some elements are accessible from inside the oven - others you have to remove the oven and get access from behind by removing a panel. Whatever you do if you do decide to remove the element MAKE SURE you TURN OFF THE POWER to the Oven. Hope this helps.
Regards
Bryan
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 338 Answers
    SOURCE: oven not heating
    you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
    Posted on Dec 07, 2008
    The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
    You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
    Aug 14, 2010 | Hotpoint Ovens
    My Neff Main Electric oven does not heat up, the fan is running, the thermostat light is lit and I have replaced the element. ???? One of your experts states that it could be the temp control or the High...
    If the thermostat light is lit, then it cannot be the temp control, as this what is causing the light to work, indicating that the power is there . I f I were you, I would ascertain that you are getting a feed to the element.
    If you are, then new element is faulty, if no feed then you need to trace the wires back to thermostat and work from there.
    Jun 06, 2010 | Neff U1721 Double circotherm Electric Oven
    Hotpoint bu 82, main fan oven not heating but the temp light and fan are ok just no heat. what would be the most likely cause, and how can i repair thanks
    It is going to be the fan oven element that has failed.
    This is located at the rear of the inner oven compartment behind a removeable cover.
    This is a very easy repair to do.
    Mar 17, 2010 | Ovens
    Hotpoint BD35 oven fan not working
    The air you can hear blowing will be from the exterior cooling fan, and nothing to do with the main oven.
    You need to check to seeif you have got a feed to the oven fan and element, the supply comes from the oven thermostat on the control panel.
    Hope this helps.
    Jan 15, 2010 | Ovens
    Oven not heating
    Hello.
    If the fan is working, but there is no heat, then it is the fan oven element that needs to be replaced.
    It has nothing to do with timer on this occasion.
    Remove panel at rear of oven compartment, there you will see the round element.
    Undo fixing screws,and remove element, disconnect leads and fit onto new element, refit new elemrnt, replace cover, and job done!!!
    Please leave a fixya rating for my solution.
    Thankyou
    Feb 04, 2009 | Hotpoint DY46 Style Line Stainless Steel...
    Oven not heating
    Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
    Oven will not light
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    Oven Problems Replacing the Igniter
    heatman101
    iuop
    Nov 19, 2008 | Whirlpool SB160PEE Gas Single Oven
    Hotpoint sy36 oven
    the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
    does anyone know how to replace the heating element, also the fan on the top isnt working either
    Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
    Ovens Logo
    71 people viewed this question
    Top Hotpoint Ovens Experts
    Colin Stickland
    Colin Stickland
    Charles T Nevin
    Charles T Nevin
    Jacques Valiquette
    Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
