Question about Dryers
Need wiring diagram for door switch is60v - Dryers
  • 80 Answers
Door switch has 2 wires.1black 1yellow. both disconnected. which goes where?
Hello Russell;
My name is Peter. I am a retired field service appliance technician.
Behind your control board you have 3 door contact switches. The top one is, "Normal" (Close operation), The middle one is, "Intermediate" (Closed operational), and the bottom switch is, "Door closed".
Usually it make no difference if the wires are the same color. You need to do a trial and error. Connect the wires to the door switch. If the microwave does not work reverse them. You will not damage the microwave.
Go into the following website, put in your model number located on a label on your microwave and you will get diagrams, and perhaps a wiring diagram. Water Filters Lawn Garden Appliance Parts
Apr 04, 2016 | Rival Rgst902 Microwave Ovens
How do I repair indesit IS60v door latch
Get on the manufactures web site and contact them through customer support and they should be able to guide you through the process. The link is most likely at the bottom of the page.
Apr 27, 2014 | Indesit Is60v, Is60vexpai, Is60vnl Tumble...
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
Just need a diagram showing how to install the
If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
What/ Color/ Where:
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel
Parking Lights Red/Black Above Fuse Panel
Head Lamp Red/White Steering Column
Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock Green/Red (-) Driver's Running Board
Horn Wire Blue/Red (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
Jan 13, 2010 | XX-67A II LED/Valet Switch Pod
I need help connecting black wire ( hot line wire) from safty switch. It fell off and I can't figuar out where to put it back on the control board.
On the reverse side of the door panel is a wiring diagram. It is in very small print so get a magnifying glass. Find "L1" on the Schematic side of the wiring diagram (the picture more like a road map). Follow the wire thru the door switch and then down to the control board. It will connect to a terminal possibly marked D1, T1, L1 or what ever the diagram says. Please make sure power is off to the heater prior to doing this.
Nov 06, 2009 | Goodman GMS80903BNA Heater
Which 2 wires go to the door on a indesit is60v
your either not measuring from the neutral connection- to the door on your meter, or you are missing the neutral connection somewhere inside the unit itself and reading a capacitive voltage reading,a/c meters will do this if not connected correct,does the unit do anything otherwise
Oct 08, 2009 | Dryers
I need the wiring diagram of pump it has 5 pins coming out of pump
hello, i holding a wiring diagram central locking system,model 201,it have a 6 pin,
  • pin no.1 brown goes to ground
  • pin .no 2 black ignition on
  • pin no. 3 red permanent 12 volt
  • pin no. 1 yellow trunk lid switch
  • pin no. 2 blue driver door switch
  • pin no.3 green passenger door switch
hoping it"s help to solve your problem,ty
Apr 28, 2009 | Mercedes-Benz 190-Class Cars & Trucks
Dryer shorting out electric supply
you have something shorting to ground check the limit switches on the heating element and all wires going to it there is a bare/broken wire some where in this circuit
Jan 10, 2009 | Dryers
Dryers Logo
461 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
