Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE SIDE BY SIDE NOT COOLING ON BOTH SIDES MOTOR IS RUNNING
Meat and ice cream not freezing. Drinks, etc are not cooling
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
djhd
Posted on Sep 29, 2010
My freezer does not keep my ice cream hard, yet it freezes meats, etc. without a problem. What is wrong?
You don't note whether or not you've adjusted the thermostat. Ice cream (and juices) requires at least zero degrees, if not minus 5 degrees, for storage. Meats, fish, bread, etc. can become rock hard at much higher temperatures. Try setting the thermostat lower.
Jun 07, 2011 | Freezers
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
My side by side is not cooling well on either the freezer side on the refrigerator side...have both sides jacked up to nine ...it is still cooling but not cold enough!! The ice cream is soft, but the meats...
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath
Aug 07, 2009 | Refrigerators
This is a simple question. What is the average
Not so simple actually. Depends for long lasting, deep freeze, meat ect you want 0 to -4 Farenheit. For Ice cream (non-defrosting) soft 20 to 24 degrees firm 15-19 degreees, hard same as meat. For defrosting models stick with the 0 to -4 as otherwise ice cream and other liquids will actually melt during the warmest part of the defrost cycle. I believe that is a self defrosting model so I'd stick to 0 degrees farenheit average.
May 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Follow up to question: meat & veg tray freezing food on new side by sid refrigerator
with very littlle ice cream I would set freezer temperature to -2 degrees and leave the humidity seting where you have it remember to let the unit run for 24 hours to stabilize then you can make another adjustment. By the way you are not being a pest I don't mind helping you at all, I am a service manager and answer quesitons allo day long.
Jan 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice cream not freezing but making ice
try turning the temperature down on the freever side. Ice Cream freezes at -10 degrees and water freezes at 32 degrees.
Dec 21, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not making ice
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
My freezer is not cooling anything, ice cream is now soup...
Make sure that the flap where the ice comes out is shut, or that the seal is sealing correctly.
Jul 15, 2008 | GE GSS25JFM Side by Side Refrigerator
GE model TFX22R ice maker problem
First clean out the condensor coils. If you have pets it should be done at least 3 times a year. The other possible problem is if the gasket in either the fridge or freezer is worn out or has a gap it will not cool properly. Check that the fan underneath the unit by the condensor coils is running when the compressor is . Some smaller refrigerators have only condensor coils on the back and no fan. These units should have room for air flow on top and sides not built in flush with cabinets. Buy a thermometer for both the fridge and freezer compartments. You run the risk of food poisoning if the fridge temp can not be kept below 40 degrees. Freezer temp should be able to keep at least 0 - 5 degrees. (Ice cream is a very good indication of proper temp. It is the first thing that melts. Ice maker is a close 2nd.)
If these things don't work call for repair. Don't risk losing all your food!
Jun 24, 2008 | Maytag MSD2756G Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
81 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
