Question about Sony DAV-DZ260 Theater System
Sony dav-dz260 push power protect problem.
I have Sony dav-dz260 5.1 Home cinema. I have "Push Power Protect" problem on the display. i bought in UK an year ago and used on twice. Now this is irritating me. I consulted sony service centre and they said problem is with mother board and they have no stock.
please cantact me if any one can rectify this problem.
9885770884
SOURCE: PROTECT UNPLUG
This is a common problem with sony it means unplug me or i will explode, it is a protection of the heat sync and usually means that a cooling fan has shorted out. If under gurentee return to Sony for repair if not under guranebntee as is generally the case check on the net for a replacement fan motor - as far as i know sony were sourcing thier fanns from Sunon there is a German based headquarters - just google sunon europe
Posted on Aug 12, 2007
welcomejee
  • 10594 Answers
SOURCE: DAV DZ260
Dear Shah ji,
I think Sony Service Center in UK can upgrade your DAV-DZ260 to play DivX files.
I live in Pakistan and can upgrade firmware if required.
Posted on Nov 04, 2008
welcomejee
  • 10594 Answers
SOURCE: DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Posted on Jun 15, 2009
SOURCE: "Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
Posted on Jun 21, 2009
welcomejee
  • 10594 Answers
SOURCE: why does push power protector keeps flashing in
This is an error massage and comes when home theater got some internal problem specially in amplifier output section that can have defective output IC etc.
It is not user level repair and requires qualified tech for fix.
Thanks.
Posted on Sep 14, 2009
My Sony dav-dz150k home theater is displaying push power protect.I checked the the sound output,the speaker wires for shorting but are fine
Hi.please check on your device control panel if you have power control key push it ,if not please see behind the device it may be there
May 22, 2016 | Sony Audio Players & Recorders
DAV-DZ290K SHOWS PUSH POWER PROTECTOR
I solved sony push protect power , please wait and difficult fault , contact 09883596400 only kolkata.
Oct 06, 2014 | Sony DAV-S300 System
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Dec 20, 2012 | Sony DAV-HDX500 System
Could yopu please tell me why my sony dav-dz260 will not turn on all fuses are working fine could it be the off on button thank you
It is possible that the power supply has failed and so a quick check on the power side will confirm the case. Check for blown fuse, and also the voltage on the secondary side.
It is also possible that the amplifier has shut down due to a PROTECT circuit. If so disconnect the speakers and test. Also try and reset the amplifier, remove power for a while and then switch on to see if the reset works.
Finally check to find if there is shorting in the output stages, if so the protect will cut off supply .Do not attempt to remove unless you are equipped as the boards are stacked and will need good soldering techniques.
Oct 11, 2011 | Sony DAV-DZ260 Theater System
Have a SONY DAV DZ370 Home theater system. Displays 'Push Power Protect'. Tried 'cold reset' and all the manual stuff to no avail. Should I reset the M16C micro-controller or is there...
Push power protect is an indication of an output failure ( Amplifier ). The Home theater system is asking you to switch off the power to prevent further damage. This mode is called protection mode and you will need professional help sort it out.
Aug 11, 2011 | Audio Players & Recorders
If "protector" and "push power"appear
There are rare occassions where a power cyle/reset can clear a protect condition, but this is extremely rare. Please see the link below for and explanation of protect mode. Feeel free to post any additional questions you may have here.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Feb 28, 2011 | Sony DAV-HDX500 System
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
Sony DAV-DZ260 Theater System Logo
357 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
